Question about Kenmore Elite 45986 Front Load Washer
\I have a kenmore washing machine model number 4904 or 4905. Can I reverse the door?
aborcass
  • 2651 Answers
SOURCE: Washing machine doors
no all washing maschines are made with a left hand hinge and are not reversable, you can reverse the dryer door if needed not the washer
Posted on Apr 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
  • 25 Answers
SOURCE: my kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: I have a Kenmore Elite washing machine-wont spin
remove the lower panel. it is held on with 3 1/4 inch headed screws. With a pail to catch the water, remove the clean out cover. Ifr the clean out is plugged, the washer will not drain.
Posted on Jul 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore portable washing machine model
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
How is the doors reversed on ffp187b
Reversing your washer door - YouTube
? 5:14
www.youtube.com/watch?v=abpAu_5Uhfc
Feb 16, 2011 - Uploaded by Kenmore You can switch the side the door on our new dryers (model #s starting with 417) swings on. This video will tell ...
Jul 30, 2015 | Washing Machines
Can I reverse the door opening on a GE WBVH6240HWW front loading washing machine
Not likely. This would require the manufacturer to spend additional money to make the door lock mechanism reversible as well. This affects the entire wiring harness. Very few machines have the ability. Usually they do sell them with the door reversed, just under a slightly different model number.
Dec 31, 2014 | GE Washing Machines
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Reverse door kenmore washer
Unfortunately it can't be done. The dryer's door can be reversed but you're stuck with the default configuration with the washer.
Oct 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
Reversing the Door
nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Sep 07, 2008 | Kenmore Elite 45986 Front Load Washer
Jun 18, 2008 | Kenmore 4292x Front Load Washer
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
415 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
