Question about Shimano Cycling
How do I remove shimano 600 pedals WITHOUT tool tl-pd10?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I can't remove the pedals - I want to remove these
Be advised the left pedal is left-threaded. Get yourself a nice Park brand pedal wrench.
What fixing nut?
How to:
http://www.parktool.com/repair/readhowto.asp?id=83
Posted on Apr 01, 2010
Removing spd pd-5700
with the tool on you should be pedalling forwards to remove them.
Jun 18, 2013 | Shimano 2013 105 PD-5700 SPD SL Pedal
I need the instructions for adjusting the tension on shimano M520 pedals
If the above answer didn't help; there are small silver set-screws on the top and bottom of each pedal. These require a 3mm allen wrench to adjust.
My recommendation is to loosen the bolt until it stops by turning it to the left. This resets them to their loosest setting. There are notches that you'll feel - it is helpful to count the notches so you know how far you have loosened the pedal and allow you to set all the mechanisms to roughly the same release tension. Then turn the wrench to the right more notches than you loosened it. Perform this twice on each pedal and you will have tightened the pedals.
Aug 03, 2012 | Shimano Cycling
Shimano Clip-on pedal's tension
Check for wear on your cleats and the pedal. Normally, the cleats wear down to the point that they get loose. Rarely does the pedal wear to that point unless damaged or very old.
Jun 26, 2017 | Shimano PD-A530
How to remove the crank set and install it
There are 3 bolts to remove on the left crank (side without the gears): 1 - the main large cap in the center of the arm (this requires a special round tool supplied by shimano with the cranks, or your local shop can sell you one), and 2 bolts holding the arm in place. Remove all three completely. If the arm still will not come off easily, then take a large screwdriver and work in between the bearings and the crank arm and gently pry off. The trick is too only move a little then go to another section and move another small amount. until the crank arm wants to loosen. Once you pull the left side arm off, the right side will pull out of the bottom bracket, Just pull straight out. the BB spindle is attached to the right side crank arm. To install reverse the instructions. Works the same on Shimano cranksets of this type.
Dec 08, 2010 | Shimano XTR Hollowtech II Mountain Bike...
What fixing nut?
How to:
Apr 01, 2010 | Shimano America PD-M540 MTB SPD Mountain...
I striped down the cleat mechanism on my SPD pedals, any ideas how to get the springs back in??
There are parts on a bike that aren't ment to be taken apart because they are unservicable. Refer to Park tool .com Dood Luck
May 07, 2009 | Shimano M324 Clipless Spd Platform Pedals
Cycling Logo
65 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
