Question about LG DLE2512W Electric Dryer
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
I have an LG front load washer (model# wm1814cw). The machine stops mid cycle but gives no error code. I have to almost unload the washer entirely and then restart the cylce. If I try to begin the
Replaced the sensor and it rocks again. I was about to buy a new washer.
1. Remove the back panel
2. Remove the center bolt that hold the cap which covers the motor coil.
3. Pull the cover out.
4. Remove all the bolts that hold the motor coil. Be carefull not to drop the coil when you take the last bolt out.
5. Remove the old sensor and replace the new one.
6. Put back every thing and it will rock again.
Jul 22, 2012 | LG WM1814CW Front Load Washer
Wm3431 pf code
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
Apr 26, 2012 | LG WM3431 Front Load Washer / Dryer
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Mar 01, 2018 | Maytag Neptune MAH5500B Front Load Washer
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't work after power outage
Inspect your motor. It maybe going thermal cutoff. Overheating this will pop the C/B. The motor will run for awhile until it heats up. When the motor colds down it may work for a few minutes.
Feb 10, 2009 | GE Washing Machines
LG DLE2512W Electric Dryer Logo
108 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
