Question about Health & Beauty
My ironing board won't stay up! I don't know what is supposed to catch on the slide bar to hold it up?
5 Suggested Answers
SOURCE: Kirby Ultimate G Upright won't stay up right
I figured out that when mine did the same thing, it was time to change the bag. It was too heavy for the handle to handle! LOL Hope that helps. Tracy
Posted on Aug 04, 2007
SOURCE: Handle on iron gets too
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Posted on Feb 09, 2009
SD Tech
  • 14553 Answers
SOURCE: smh1611b door won't stay closed
either a bad latch unit or one out of position---has to be opened up to see which.
Posted on Nov 07, 2012
cdeuce2001
  • 10 Answers
SOURCE: Trunk won't stay up
The bar,called a strut snaps on to a small piece that is connected to the chassis of the vehicle.It should have a clip that lifts up,put the end of the strut over the piece on the chassis,and push the clip back down.You dont even need tools.
Posted on Nov 22, 2012
How to put chain back on when it falls off
Almost every saw has a cover where the bar locks onto the saw, you take off the cover just as you do if you needed to remove the bar.
Just loosen the two or one bolts that hold the bar and slide the bar back, put on the chain and slide the bar back out.
Now there is suppose to be some play, the chain is not suppose to be very tight.
Here is what it suppose to be like.
Read this link that I post, it's easier to read this then me trying to explain it.
http://www.instructables.com/id/How-To-Tighten-a-Chainsaw-Chain/
Apr 14, 2013 | Poulan Pro 14" Gas Chainsaw 33CC P3314
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
I just took apart a Sunbeam iron. This is how it disassembles:
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Mar 27, 2011 | Sunbeam 4214 Iron
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
My tv fickers and shuts off ?
SYMPTOM:
Clicks and turns off after turning on set when cold. Have to turn on and off several times to work, or keep changing channels, right side of screen is black for a while.
PROBLEM: It is almost always a bad transistor and a bad capacitor. (about $0.70 in parts)
SOLUTION:
This repair is fairly straightforward. You will need a soldering iron, a solder ******, and a small torx bit. Unplug the set. Lay the TV on the floor, screen down. Remove the torx screws holding the rear cover on. There should be 10, (don’t forget the 2 by the input panel). You will see 2 circuit boards, the one of interest is the large one near the bottom of the set. This board has a retainer clip on each side that needs to be pulled out to allow the circuit board2.gif to slide out. Slide the board out about 5-6 inches. You might need to support the board so it doesn’t slide back down into the TV set. This circuit board should have numbers by each of the components. You want to look for 7461 (transistor) and 2455 (capacitor). They are located right next to each other near the center of the board. The transistor will usually overheat and discolor the circuit board immediately around it. Warm up the soldering iron and get the solder ****** ready. Heat up the solder joint while removing excess solder with the ******. Once the transistor and capacitor are free, check the numbers on each. The capacitor (round cylinder) should have “47uf” on it. The transistor should have “C33725” on it. You can order these parts from Digi-Key (google it) for about $2.50 including shipping if you use USPS option. The part numbers are: 493-1060-ND for the capacitor and BC33725-ND for the transistor. Once you get your parts, solder them in and check TV operation. It should work as it did before. This repair can be done by anyone familiar with a soldering iron in about 30-45 minutes their first time. Good Luck!!
Jun 28, 2009 | Philips 27PT543S 27" TV
BRAKE LITES WON"T WORK
you have a corroded ground in the back light bar..remove the rear light bar from the fender and make sure it is clean, not rusty.
Mar 10, 2009 | 1995 Honda VT 1100 C Shadow Spirit
Thanks for your support
Remove the keyboard screws first, the screws that secure the keyboard have keyboard symbols next to the screws.
Some Compaq/HP have slide catches along the top edge of the keyboard between the number keys and the Function keys. Usually the slide catches are located between the ESC & F1 key, F4 & F5 key, F8 & F9 keys, F12 & delete keys. Slide these catches towards the front edge of the keyboard (ie. towards the space bar) you should be able to lift the keyboard clear. Don't forget to unclip the ribbon cables on the keyboard.
Jan 28, 2009 | HP Pavilion dv1000 Notebook
Health & Beauty Logo
792 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
