Question about Maytag Heating & Cooling
My air conditioner is no longer blowing cold air
    Problem Solver:
  • 6 Answers
When the ac is on and cooling the out door units fan should be on hold your hand over the fan if it is cool the compressor is not coming on or it is low on freon .check the capacitor it is usually shaped like a coke can sometimes it is oval don't touch anything while the breaker is on.Turn off power and check to see if the capacitor is bulging the top and bottom should be flat .If it is leaking or bulging you need a new one.Even if it is not bulging it could be bad if in doubt call a serviceman. Changing the filter can fix a lot of problems so try that to
Posted on Sep 19, 2010
  • Maytag Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 04, 2010
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
My coleman mach air conditioner will blow cold air for around 4-5 hours then air is no longer cold? I could turn it off for a few hours and it will blow cold air again? what could be my problem?
sounds like the compressor is going in to overload this is a protection if it gets to hot make sure your condenser fan motor is working properly and that your condenser coil is clean I would rinse it out anyway to make sure. when you shut it down you are allowing the compressor time to cool down and it restarts but you have a high pressure head problem .
Jul 31, 2011 | Heating & Cooling
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Frigidaire FAH125N2T Air Conditioner is 6 years and still runs very smooth but no longer blows cold air. What could be the problem?
heatman101
Sep 04, 2010 | Frigidaire FAH125N2T Air Conditioner
No longer blowing cold air
heatman101
Aug 30, 2010 | Danby Portable Air Conditioner
My air conditioner is not blowing cold air. What can be done ?
look for a couple of things ... if the compressor just buzzes intermittantly but doesnt run then suspect its starting capacitor (small rounded metalic rectangle) .. that has wires connecting it to the compressor .. .. if you can hear the compressor start but it still doesnt cool then you likely need refrigerant added .. thats done by adding a saddle valve service port ... any leaks have to be repaired ..
Jul 25, 2010 | Haier Mechanical Air Conditioner HWF05XC7
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Air conditioner not blowing cold air-
yes ,but u need to retrofit it for 134a if it hasnt been changed over already,parts will have every thing u need.charge hose and fittings and get ester oil charge to complet correct retofit if u need more info e mail me roniecon@gmail.com
Jul 04, 2009 | 1993 Buick LeSabre
Heating & Cooling Logo
103 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
