Question about Sharp AM-400 Digital Multifunction Printer
FAX RX IN MEMORY AND FAX TONER EMPTY ERRORS AND I CANT RECEIVE MY FAXES BUT I CAN SEND IT...PLZ HELP
    President:
  • 2,571 Answers
It sounds like your toner has ran out, so you cant print any more faxes out, the memory saving the unprinted faxes has filled up and cant save any more messages.
Replace the toner and let the machine print out the saved faxes. You should then be back to normal
Posted on Sep 04, 2010
FAX NOT RECIEVING
Have you tried the simple things yet? Have the sender send you one page with a single word on it like TEST.... See if that works.
John
May 05, 2014 | Ricoh Aficio SP C240SF
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Cant send faxes
It sounds like the faxes memory is full, either from receiving or transmitting faxes, try turning it off and on again, the fax might just need to recognize you have installed a net toner cartridge.
Oct 16, 2009 | Office Equipment & Supplies
I have a konica bizhub 200. We can send faxes out
As a first thing to try, with most faxes that send but do not receive, it's usually down to a glitch.
Try shutting the bizhub down fully, then unplugging it physically from the power source for at least 30 seconds. Plug it back in and turn the unit back on, then have someone try and send you a fax.
If this does not remedy your problem, please indicate with a follow-up comment.
Aug 28, 2009 | Minolta bizhub 200 Copier
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Fax machine problem
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Nov 07, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Fax not printing
may be you are having tonner empty error
press menu(*) #1934 menu(*) select new cartige then u will able to receive fax to print
jignesh
Aug 12, 2008 | Samsung SCX-4216F All-In-One Laser Printer
274 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
