Question about E-Machines eMachines Desktop PC
I ADDED NEW MEMORY AND THE COMPUTER WONT BOOT I JUST KEEPS RESETING AND DOING THE SAME THINGHOW CAN I FIX THIS.
  • 70 Answers
There are several things that could be wrong here: 1. You didnt install the memory correctly, open it back up and remove the memory sticks and reinstall them 2. Try putting only one memory stick at a time, maybe one memory slot is bad. 3. One of your memory sticks could be defective 4. You got the wrong memory sticks for your computer and they are incompatible with your pc, contact your computer manufacture to find out the exact memory sticks you need.
Please leave me a good rating.
Posted on Sep 04, 2010
Everex ga3400 wont boot just beeps
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Remove added memory If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced. Replace memory If it is determined the memory in the computer is bad we suggest that you replace it if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
Feb 25, 2013 | Everex GA3400 PC Desktop
My computer lenovo desktop thinkcentre beeps 1,3,3,1 i chaged the memory RAM but no effect seen it continue beeping at booting process, please help me
Cause
Computer RAM (memory) related issue.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page.
Remove added memory
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Replace memory
If it is determined the memory in the computer is bad we suggest that you replace it.
May 19, 2011 | Lenovo ThickCentre M58p Desktop 7479A3U
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
Did not boot and with 3 beep sound
Remove added memory
Replace memory
Aug 04, 2009 | Computers & Internet
RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Jan 14, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
COMPUTER DOESN'T RECOGNIZE ADDED MEMORY
Are the memory cards the same? Try swapping the memory cards inside the computer. It is also important to go into the Setup (F2) once the new memory has been added. The setup keeps track of the hardware changes to your computer, and the additional memory needs to be saved in the Setup configuration. Please let me know what happens and thank you. Binary Bob
Dec 27, 2008 | Dell Dimension 1100 PC Desktop
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
My computer crashes now and then... Tends to happen alot when im playing a pc game? It makes this loud screeching noise when it freezes i am forced to shutdown manually
Your Memory card is the problem.
Try this steps:
1. Remove added memory
2. Open computer and reseat memory
3. Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
4.Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Aug 25, 2008 | Computers & Internet
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
