Question about Pioneer DV-575A DVD Player
My dvd player keeps turning itself off. Whenever we swtich it on, it turns on for a few seconds then the tv goes "!No Sync. Signal" and the dvd player switches off. It is a Pioneer DVD player (DV-575A). I have had this dvd player for about 6 years. To fix it, we tried making sure all wires we plugged in, we changed the batteries of the remote and then we tried switching it off, removing the plug, waiting for ten seconds, and then plugging it back in.
likha
  • 790 Answers
SOURCE: No Power
ok! make sure ur IC regulator is good. like the 7805 or 7812 or 7809 u make sure that the following ICs are correct in voltage! 7805 is for 5V. 7812 is for 12V. 7809 is for 9V MAKE SURE THAT IS EXACTLY IN VOLTAGE!
Posted on Aug 15, 2007
SOURCE: how to use the usb port on Pioneer DV-410V DVD Player
Dear friends in problem solving.
My husband actually solved this problem by writing in the browser: Manual for Pioneer DV-410V DVD player.
That was available online and there it said that not all formats was supported by the USB port, so we tried to load a movie on a pen drive, insert it in the player and it opened and we just clicked play, so it was actually an issue of having an incompatible video file on the pen drive that made it not open in the first place.
Hugs from Solvejg
Posted on Dec 09, 2008
SOURCE: I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: How can I make a Pioneer DV-420V-K DVD Player Region Free?
this involves burning a cd of new firmware
try here
http://www.videohelp.com/dvdhacks
Posted on Apr 12, 2010
  • 3 Answers
SOURCE: Pioneer DV-C36 disc tray will not stay open
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract
back into the unit leaving no time to change or load disks.
I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable
connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted.
On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which
causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor.
I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers.
This is very tedious and required an eye loupe for magnification.
Tools required:
#1 and #2 phillips screwdrivers
Soldering and desoldering irons (or other desoldering tools)
Fine needle nose pliers.
Remove the tray ribbon cable
1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended.
2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract.
3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release
two catch tangs on bottom edge using a small screwdriver on the inside of the unit.
4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw.
5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit.
6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray.
Pull the tray out further then lift up.
7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws
holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly
to press against the ribbon cable conductor. You can either replace the connector or repair it.
Warning: repairing the connector may damage it.
To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the
connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
Posted on Nov 19, 2010
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
I have a Magnavox 15MF400T/37 LCD TV operating with a cabel connection. As of yesterday it has no functions but when I turn it on I get a message that says Attention No Signal. I have checked the cable...
Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
Jul 21, 2008 | Televison & Video
I have a Sony Bravia KDL-22BX300. When I turn it on, within the first few minutes I get this loud blast of static-y noise & the picture goes all snowy. It'll last approximately 10 seconds, then the...
This problems it is the tv Tuner signal board itself it is dying,just not dead yet.This problems the tv Tuner signal board is slowly dying,when it is completely dead.Ur tv will have only LED power light indication.No broadcasting tv signal at all.The tv Tuner signal board,that the board,where the incomming broadcasting signal cable plug into it.U can wait until it completely dead or like to change it now.Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Jan 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The screen won't turn on. But, whenever you press the on button it turns red like it is turned on. What's wrong? And how can I fix this?
A very common problem with this TV model. You have a bad signal module or a bad small signal board. Leave your TV unplugged for a few days or a week. Then plug this TV and power on. If the TV comes on and plays well for a few seconds and goes out, the SSB needs replaced. The second thing would be to pull the back cover off. If TV is already on,you can see the rear filaments on the TV tubes lit. Still no picture..then your the signal module is bad and the Convergence ICs and resistors will need replaced. This is a good starting point. Definitely one of these two problems.
Nov 21, 2010 | Philips 50P8341 50" Rear Projection...
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Oct 07, 2008 | Akai LCT2721AD 27 in. LCD Television
Component Video losing sync with too much White signal
I had this exact same issue. I tried two different component AV switches, and shorter cables to prevent signal loss, but any time there was too much white on the screen, the video still lost sync. Plugging the sources directly into the TV solves this problem, but since I have a DVD player, a game console, etc, this was not acceptable. The way I resolved it was to (sadly?) buy an expensive component AV switch that can support the bandwidth without losing the signal.
I wound up spending the extra money on a Key Digital 4x1 component switch. It is much more expensive, but it works.
May 02, 2008 | Onkyo TX-SR604 Receiver
DVD playback color
When passing the video signal thru a VCR on the way to the TV, you are activating the DVD's "Macrovision" copy protection.  You need to hook it directly to the TV.
Jan 27, 2008 | Philips DVP642 DVD Player
Pioneer DV-575A DVD Player Logo
238 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
