Question about Car Audio & Video
The screen doesn't flip out - Car Audio & Video
  • 36 Answers
Possible motor or mechanisim failure. i think you may need to get a technician to look at it as from experience these units can be very tricky to work on if you dont know what you are doing. hope this helps
Posted on May 12, 2008
Captian krunsch stuck on my screen and I alrady beat him what should I do ? please help me !!!!!!!!!
Try flipping him off. If that doesn't work, call Tony The Tiger to bite him in the ****.
Mar 06, 2012 | Cars & Trucks
When you switch the phone the screen lights up blank and goes off quickly and also the keypads doesn't light up during that time whats wrong with it
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Good luck.
Oct 27, 2011 | Sony Ericsson W850i Cellular Phone
No I didn't what is wrong with my phone is the sreen flip from vertical to horizontal doesn't work anymore and was wondering how to fix it
Go into your phones settings and usually under "DISPLAY" there will be a screen orientation setting make sure it is set correctly. Its also possible the phones accelerometermay be malfunctioning
Sep 08, 2011 | Cell Phones
How to flip screen around
The 6th generation iPod nano doesn't have an accelerometer, but its screen can still be rotated. Here's how.
Begin by putting two fingers at corners of the screen. This can be opposite corners (one finger at the top right corner of the screen and another finger at the bottom left corner, or vice verse) or corners on the same side (top left and bottom left, for instance).
At the same time, twist your fingers in the same direction (clockwise or counter clockwise). The screen should rotate with your fingers. Remove your fingers from the screen when it's oriented the way you want.
If you like my solutions kindly rate it.
Thank you
May 20, 2011 | Apple iPod Nano 6th Generation MP3 Player
What is the mobile number of this rim number (8991211460000908890) please send me query immidietly...
you need the imei # of the phone the rim # just lets people know exactaly whats in the phone example
81xx - Suretype, Non Flip, Camera
82xx - Suretype, Flip, Camera
83xx - QWERTY, Non Flip, Camera
85xx - QWERTY, Non Flip, Camera, Expanded Internal Memory
88xx - QWERTY, Non Flip, No Camera, GPS, GSM
89xx - QWERTY, Non Flip, Camera, High Res Screen, Expanded Internal Memory
90xx - QWERTY, Non Flip, GPS, Camera, High Res Screen, Expanded Internal Memory, 3G, WiFi, Video Recording
95xx - Touch Screen, Non Flip, GPS, Camera, High Res Screen, Expanded Internal Memory, Video Recording, GSM, 3G
96xx - QWERTY, Non Flip, Camera, High Res Screen, Expanded Internal Memory, GSM, 3G
And now the last 2 digits
xx00 - Base Model, No modifications
xx10 - GPS, GSM, Video recording
xx20 - WiFi, GSM, Video Recording
xx30 - CDMA, EVDO, Video Recording, GPS
xx50 - CDMA, EVDO, Video Recording, WiFi, GPS
the phone you got for example would be a "Non Flip, Camera, High Res Screen, Expanded Internal Memory" the other numbers in the rim also tell more about the phone. but a persons phone # can not be found using this #
Oct 06, 2010 | Cell Phones
External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Display will not show when tv flips out!
MOST SCREENS R NOT ON IN THERE RESTING STATE, THERE USUALLY A MECHANISM THAT TURNS THE SCREEN OPEN WHEN IT OPENS, TRY SLIGHTLY PUSHING THE SCREEN BACK LIGHTLY TO SEE IF IT COMES ON HOWEVER IF U CAN RESET IT , TRY THAT IF THAT DOESN,T IT WOULD HAVE TO BE REPAIRED FROM THE MANUFACTURE
Sep 02, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Did not drop/but screen sticks
It doesn usually happen when dropped. You may be able to fix it by removing the flip screen and rotating spring action fli[p piece.
The following instrutions are for a sidekick 3 lcd screen but it is the same for a sidekick id.
http://repairmysidekick.org/Remove-and-Replace-Sidekick-3-LCD-Flip-Screen
Feb 25, 2008 | T-Mobile Sidekick ID Cellular Phone
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
