Question about Health & Beauty
I have just aquired a shoprider deluxe TE889af scooter and it has a fault,it is fully charged but as soon as you operate the accelerator it barely moves and keeps clicking.I've tried to get a manual for it on line but had no results.
Ce putere are motor shoprider TE-889-AF?
Posted on Apr 25, 2014
  • 11 Answers
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
Posted on Apr 02, 2009
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
  • 103 Answers
SOURCE: HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
skaterkid307
  • 86 Answers
SOURCE: scooter stops then jumps forward
mait be problem with moter
Posted on Feb 20, 2010
  • 347 Answers
SOURCE: shoprider delux scooter
check key tubler is not faulty,no connection has been or worked loose,fuses for each battery are not blown press curcuit breaker to reset.get the wiring feed checked from batteries to see you have power by an electrician.
Posted on May 12, 2010
How to find serial number and model for Shoprider deluxe
Hi most scooters have serial numbers & date of manufacture on the frame around the transaxel under the rear cowling cheers
Apr 25, 2016 | Shoprider Sprinter Deluxe Four Wheel...
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Regard
Rob
Help me Help you ...
Sep 24, 2015 | Shoprider Health & Beauty
My Shoprider does not have a constant speed, even with new batteries and fully charged.
This is a sign that the Wig-wag control is at fault or motor brushes need attention. Your husband is on the right track. you will need to take to a service centre for attention.
Apr 13, 2015 | Electric Mobility Shoprider Electric Power...
My shoprider deluxe is fully charged ignition on and wont go
Does the scooter making a bleeping noise when you turn it on? Do all the lights / indicators work (if you have them fitted)
Sep 21, 2013 | Health & Beauty
My Battery on my Shoprider Delux is fully charged but lasts only about 45mins is my Battery Knackered?
first of all , this is a common mistake , can you borrow another charger to make sure that is not causing the problem , you need to convince yourself that the charger is okay then lok at the batteries located under the cover located under the seat, make sure the batterys connectors are clean and tight, if all fails sadly it is a batteries replacement.
Nov 21, 2012 | Shoprider Sprinter Deluxe Four Wheel...
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
My father inlaw has a Shoprider Deluxe scooter, it is fully charge, all the fuses are good and the circut breaker is good. When we turn the key on it has fuel power and seems ready to go. We move the lever...
If you have followed all the trouble shooting guide in the back of the manual then it could be one of a few things. either the Wig-Wag control is at fault (the lever you press to go forward/ backward) or the control/drive unit is at fault. You will need to take it to a service centre to have it looked at or repaired. Shoprider are made by Roma medical and their web site is ;- http://www.romamedical.co.uk/ if you need a manual you can download from here.
Aug 09, 2010 | Electric Mobility Shoprider Dasher 4wheel ...
Shoprider xl4 deluxe has no power on inclines. lucky if it goes a couple of blocks even on the slightest grade ang the battery gauge goes to 1 light. Even with a fully charged battery has no guts on hills...
`Hi. Sounds very much like a loose battery terminal, or a faulty battery lead connector.
I have also had a few machines that can start jerking because of worn or stuck motor brushes.
Also check the high/low speed switch if you have one, they sometimes cause problems.
How old are your batteries, worn out batteries can still be " fully charged", but are unable to supply the current ( amps ), that the motor needs.
Good luck. Neil.
Jun 27, 2010 | Shoprider Sprinter XL4 Deluxe 4 Wheel HD...
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Health & Beauty Logo
341 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
