Question about Saunacore Special Edition 9Kw 450 Cubic Ft Home Sauna Heater ( Kw 9 Se ) ()
I have a KW 7.5 Ultimate-it will run for 15 minutes and then shut off-and will not restart until the room cools down and the reset button is pushed-the room doesnt even get warm
    President:
  • 2,702 Answers
Check the thermal censor in unit (faulty) or thermostat (faulty)
also check the air flow around unit this must be free to breath in fresh air or the unit will over heat and shut its self down
Posted on Sep 04, 2010
Tractor starts and runs well for 15-20 min., then why does it shut off?
Hey John!
Have you check the OIL some of these engine have a low oil shut-off sensor feature built-in ?
Check also that the fuel is not contaminated (Fresh Gas, please!)
Good Luck,
JP
Oct 28, 2015 | Garden
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Rinnai Avenger 25...Thermostat is on 26 but the room is no where near that hot??
the heater will attempt to heat the room until temp is reached if door is opened or cool air enters the heater will continue to run if the heater is set to 20 when the room reaches 20 the heater will shut down until temp drops below 20 then restart
Jun 12, 2011 | Rinnai Heating & Cooling
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Is their a reset button for a L800 HOBART? Hit start sparks flew.
Yes,
DISCONNECT POWER
if you remove the top cover, you will find an overload group with a green and a red button on top, next to the contactor . One is test, the other is reset. On the side of the overload are two thumb wheels, one is auto/ manual, set this to auto, the other is -15%,0, +15%. If you are running very heavy batches and you want to push your motor harder, move it to +15, but it's not recommended. If it was set to manual, when it trips and cools down, it will not reset untill you press the reset button, in auto, once cool you an restart the mixer.
Nov 30, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
Vapor lock?
keep the fuel tank at least half full.....it may helps cool the pump
Jun 19, 2008 | 1991 Volvo 240
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Saunacore Special Edition 9Kw 450 Cubic Ft Home Sauna Heater ( Kw 9 Se   ) () Logo
116 people viewed this question
Top Saunacore Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Saunacore Pool and Spa Expert? Answer questions, earn points and help others
