Where can i get the kit to add freon to my 2004 kia sedona?
  • 107 Answers
Any good auto parts store has the cans with the guage built into it showing Low, Good, Danger.. Try that out... Let me know if you need anything else
Posted on Sep 05, 2010
I need a wiring diagram for a 2004 KIA sedona
BBB Industries online under Technical
May 25, 2015 | 2004 Kia Sedona
2004 kia sedona ex ac not working can jump ac
You could have several problems. If your pressure readings (freon) are low it will not kick on the clutch for the compressor. Do you happen to know what your pressure readings are when you do jump it or what they are (low or high pressure side) when it isn't engauged? Also you could be dealing with a relay or a sensor that detects your pressure readings. Really knowing your pressure readings would be a start before I can begin to help.
Sep 03, 2013 | 2002 Kia Sedona
Where is the expansion valve located on the 2004 KIA Sedona
Kia Sedona expansion FRONT valve located under dash, behind glove box, fan and coil. Evacuate freon first. Disconnect Freon lines from firewall., Lay right front seat back to flat horizontal position and lay on top or totally remove the seat for easier working access. Remove under dash cover, fan, glove box, coil housing, remove coil mounting bolts, remove old expansion valve. (Inspect old valve, if debris inside, blow out coil before installing new valve. If visible debris best to consider replacing REAR expansion valve and DRIER/FILTER in front of radiator too and blow out all lines and coils while servicing.) Use compressor oil to lubricate "O" rings on new FRONT or REAR expansion valve, install valve bolts, reinstall coil bolts to FRONT firewall or REAR frame, reconnect freon lines to firewall in engine compartment. Evacuate AC system, install freon (35 1/2 ounces, nominal 3 pounds), check system for leaks, check for proper operation, enjoy.
Sep 12, 2012 | 2004 Kia Sedona
How to recharge ac
For DIY folks, you get a recharge kit from an auto parts store and connect it to one of the ports on the ac line.
Instructions come with the kit.
Keep in mind freon gas is about 30 degrees below zero coming out of the can.
Jul 13, 2012 | 2002 Kia Sedona
Trying to locate ac areas on a 2004 kia sedona ..I'm sure it just needs a shot of r134a...I have the 16oz bottle with gauge...just don't know where to bleed and install
being an 04 there is a reason ur a/c isnt working. even if it is because its low on freon that means that it leaked out and the leak needs to be fixed b4 adding freon
Aug 07, 2011 | 2004 Kia Sedona
My 2002 kia sedona is leaking coolant from the rear by the spare tire causing the van to overheat.What are the possible problems and estimated costs to repair.
your rear cooler lines are leaking-they rust out(very common)the cooler lines are sold as a kit-include both going to rear-youll have to call around for quotes-when i worked at a kia dealer the repair was around $400-$600
Feb 17, 2010 | 2004 Kia Sedona
Kia sedona a/c compressor is not engaging.check the fre.it is good.
If there is 12 volts at the compressor,then the coil on the clutch is bad.Most of the time,compressor with coil/clutch,is cheaper to purchase than just the clutch.I hope this helps you.
Aug 18, 2009 | 2003 Kia Sedona
What is the easiest way to remove my air compressor from my 2004 Kia Sedona Mini van??? manny.
Make sure there is not any freon in the system. Remove the belt. Unbolt the 2 lines bolted to the A/C compressor. Unplug the electrical connector to the compressor, remove the 4 bolts holding the compressor to the bracket. Take it out from the bottom.
May 14, 2009 | 2004 Kia Sedona
2002 KIA Sedona and A/C blows hot air
well you are probaly loew on freon our the comp is bad find the comp and see if you are able to move it if you can than you should find someone that can add freon
Mar 25, 2009 | 2003 Kia Sedona
Where do I add the coolant to my 2004 KIA sedona?Thanks..
You add coolant to your reservoir/ to make sure you have enough open the radiator cap while it is cold put coolant/ water 50/50 mix put in fluid then have some one turn vehicle on stand back and then let the system burp itself it will bubble then you will know if you need any more mix. then close cap and you should be ggood to go/ Please rate my response thank you very much
Jan 13, 2009 | 2004 Kia Sedona
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
