Question about Mk Diamond Saws
It blows house breaker, immediately after its turned on.
  • j_liston Sep 05, 2010
    breaker is fine (20amp) need to fix saw motor. was working fine but after cutting several stone it started to blow breaker. Want to know how to fix and/or where to take it to get fixed in Denver, CO
    NOT THE BREAKER FOR THE LAST TIME
    Last chance to look at my question
  • 2,100 Answers
You have either got a gfi receptacle, 15 amp breaker, or using a cord that is too small. That saw draws 15 amps + at start up and runs at 13 amps. or more. So a 15 amp breaker won't run it. Any cord except a big giant one will lose enough amps to stop the saw from running and trip the breaker, A GFI breaker or receptacle will snap off in a heartbeat without enough juice. Or the slightest thing wrong with the cord, no ground, or whatever. gte to a 20 amp breaker, or a bigger cord, and stay away from the gfi. Hope this helps.
Posted on Sep 05, 2010
  • 10,319 Answers
Compare the amp rating to the breaker and what is connected to that circuit as well. It maybe from an overloaded circuit. Use a different circuit to find out with the unit
  • 43,501 Answers
Either the motor/saw has a short in the motor or wiring or the breaker is not heavy enough/or bad..... some breakers will not handle the surge of a motor starting up and are very sensitive to that...
I would try a differnet circuit breaker/outlet and also check the start up amps of the motor...it may be pulling high amps on the start...
heatman101
Posted on Sep 04, 2010
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
Aqua spa pack breaker tripped
A breaker trips if it getting feedback. Feedback can be caused by water or a crossed wire, or an electrical component failure. You said it's pumping water on the ground so the pump is working. Then if you put it back in it trips, so you pump isn't able to push the water to where it has to go and therefore your getting a pressure buildup which falls back on the pump sensors and stops it before you blow up something, it is saving you from disaster of property or personal injury, this is a good thing. You have a clog in your pipes or you have a valve that is closed that shouldn't be, but it's the back pressure that is blowing the breaker I think. I take it it is on an isolated circuit in your house and isn't sharing anything else that could be drawing to much on that circuit. Anything electronically new in your house? I don't think it's electrically related just asking.
Jul 14, 2012 | Aqua Pool & Spa
2007 harley heritage blows turn signal fuse
Hi Anonymous, check your handlebar switch housings for pinched wires and for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 26, 2012 | Harley Davidson FLSTC Heritage Softail...
Kenmore elite he4 blows circuit breaker
your element or motor has shorted as these r the only components that r earthed within the machine so check these first
Nov 10, 2011 | Kenmore Elite HE4 Electric Dryer
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Water light still showing ,also blowing cold air
Assuming that this not a gas dryer. Check the dryer pair of breakers in the house electrical panel--push OFF, then ON. If breakers immediately re-trip, then there is a short to ground within the dryer case--usually the heating element.
Aug 02, 2009 | Dryers
Breaker blows when I turn oven on
sounds like the 240v terminal block in the back of the oven may be grounded out.. either that or the yellow wire that runs up the back of the oven may be shorted..
Feb 20, 2009 | LG LMV1630 Convection/Microwave Oven
Blows main house breaker
I would disconnect the heater element.When you turn the unit back on and all is ok the element is bad if not the pump motor is your problem.
Jul 19, 2008 | Zanussi Dishwashers
Saws Logo
147 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
