I forgot my network key for my belkin g router and don't really want to buy another one
  • 45 Answers
Underneath the router there is a reset button use a small screwdriver to hold this in for about 10 seconds that will reset the router to factory de fault then you can set the fouter up again
Posted on Sep 04, 2010
    Problem Solver:
  • 12 Answers
  • Get a long and thin object. A heavy gauge straight pin, a push pin, or even the tip of a sharpened pencil will do for this project.
  • Locate the reset button on the back of your router. It will be small, rubbery, and inset into the case. The word "Reset" will be below the button.
  • Turn off the computer, and disconnect the router from the computer. Leave the power to the router connected to a power source. This will not work if the router is powered off.
  • Press the reset button with the long and thin object that you picked out in step one.
  • Count to seven slowly. After seven seconds you can let go of the button.
  • Look for the buttons on the front to flash. When you have reset the device the lights will all flash at the same time. If you are not looking at the right moment you may miss this brief flash.
  • Posted on Sep 04, 2010
      President:
    • 2,571 Answers
    You can reset the router to factory defaults. there is a reset hole on the back of the router to push something thin in for about 20 seconds. Just google belkin factory reset for more info if you cant work it out
    How do I recover from lost guest password?
    If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
    Dec 09, 2015 | Belkin Wireless Dual-Band N450 Router
    Forgot pass key
    Reset the Belkin to default settings and reconfigure the SSID and the Security Key. You can find a User/Setup Manual here: http://www.belkin.com/networking/manual/MAN_F9K1103_8820-00778_RevA01_N750.pdf
    May 26, 2013 | Belkin N750 DB Wireless Dual Band N Router
    I forgot my wep key
    Either call Belkin or your ISP or hard reset the router and then configure your network again.
    Jun 21, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
    Forgot the network key. Either I want to get the network key or I want to reset the network key to something else
    If you can access the router setup page, you can still get the network key that you need and if you can also access the router setup page you can also do change the network key that you have on it...
    Dec 29, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
    Need network key for belkin g+ router 802.11g
    if you own the router and you don't know the network key or forgot it.
    you need to reset your router, please check the intructions that came with it. if you haven't change the admin password (which is by deafult blank) go into the admin page and change or delete the network password doing something similar to this
    if you don't have or can't remember the admin password you need to restore the router to defaults to reconfigure it
    if you don't own the router and don't know the network key you need to ask the router owner for the key or use a program to hack into the router signal and attempt to figure the key out. (not recommended as it is ilegal)
    Dec 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Forgot my security password (network key)I need to
    Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
    The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
    Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
    Nov 16, 2009 | Belkin (F5D7230-4) Router (587009)
    Is belkin router f5d8230-4 a g or n? i need tyhis
    It is a PRE-N router, which means:
    When you see a “pre-n” product, it is one designed based on the future “n.”
    standard, but is not a standard. It will generally only work with that companies devices, which means if you buy brand XYZ’s wireless router, you will also need to buy brand XYZ’s wireless networking adapters for all of your computers.
    Interoperability between pre-n and non pre-n devices can be difficult and even if you get it to work, you don’t gain anything unless everything is pre-n.
    Jun 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
    Left network key for belkin router behind in states
    Try dooing a Compleete reset of your router. there is a tiny tiny hole on the bak side of your router ( sometimes on the front ) and it should say RESET engraved over it, find a tac or a small needle ( maybe toothpick ) and hit the reset butten behind the hole, make shure it says " RESET " over the hole, and dont push to hard, leave router standing for a cupple of minutes and try the default WEP key listed on the underside of your router.
    for more details, please visit "http://www.belkin.com/support/article/?lid=en&pid=F5D5231-4&aid=1564&scid=0"
    Mar 02, 2009 | Belkin (F5D7230-4) Router (587009)
    Forgot network key
    Do you remember your router password? If so, there are probably ethernet ports on the back of the router that you can connect to with a cable. Log into the router and change the key.
    Dec 13, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
    I have forgot my network key is there a way to get it back ?
    pull up the interface of your router, click wireless tab, it can show the network key. what's your router?
    Computers & Internet Logo
    David Payne
    David Payne
