Question about Kenmore Microwave Ovens
The exterior lights ( the ones that light the stovetop below) no longer work on my Kenmore over-the-range microwave model 721.80599400. I have in the past, replaced a light bulb, and it worked. In this case, I replaced both bulbs, and neither light works. What do you think might be the problem, and can I fix it myself?
  • John Lukasik Sep 04, 2010
    WRONG MICROWAVE. THE ONE YOU REFERENCED IS A WHIRLPOOL.
    MINE IS A KENMORE.
    ANY OTHER SUGGESTIONS?
    THANKS,
    JACK
  • Kenmore Master
  • 3,247 Answers
I am assuming the oven you have is as shown in this manual.
It is possible the key pad for the cook top lights is not working.
Did you check if the lights were actually blown when you replaced these?
Take a clean damp cloth and rub over the key pad a few times to remove any trapped impurity under it.
Have you checked the filters are clean and no grease is spreading into the lamp sockets?
Please post a comment to confirm if you find anything based on my observations.
Posted on Sep 05, 2010
  • 3,083 Answers
I found the following web page, which is your exact problem, and the things you can do to try to fix it:
http://forum.appliancepartspros.com/microwave-repair/113800-over-range-microwave-range-lights-not-working.html
If the following website has your model, they will have neat diagrams and a list of parts:
http://www.appliancepartspros.com/
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 04, 2010
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Replaced microwave bulbs, light still doesn't work.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 10, 2010 | Panasonic Microwave Ovens
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Mar 27, 2009 | Kenmore 62643 Microwave Oven
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Switch for stovetop light on Goldstar over-the-range microwave
This is caused by a failure in the Sharp solid state relay "chip" (S201DH2). The newer pin-compatible versions don't seem to suffer this weakness. I used the R31HD2 (http://document.sharpsma.com/files/pr21hd22_e.pdf) which should still be available in the US for less than $10 delivered from Mouser or similar retail friendly parts houses.
A simple repair for someone with the tools and basic skills for removing and replacing a chip that is soldered to a printed circuit board. If you lack either of these, better to order a replacement board or have it serviced professionally.
Dec 11, 2008 | Goldstar Microwave Ovens
Kenmore Microwave, overhead household, Model 721-6264900
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating items
if it is fuse then there should be no lights or display at all. if there is, then it is not a fuse. it could be the magnetron.
the fuse is located inside the microwave. you have to bring it down and open the cover.
i hope i was able to help
pls rate me..
tnx ,
drcool
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
