Question about Epson Stylus NX515 All-In-One InkJet Printer
I replaced 2 cartidges. When I replaced the magenta the printer kept doing fine. When I replaced the black 20 minutes after the magenta it doesnt recognize the cartidge and I put another black cartidge in and it still doesnt recognize it. I've had this printer for about 4 weeks
    Problem Solver:
  • 12 Answers
Make sure there is nothing between the print cartridge and the place where it goes. Make all the plastic is removed from the cartridge. If you have a can of air, blow out the cartridge area.
Posted on Sep 04, 2010
Hp 2840 was printing light in black, so I replaced the cartridge, did a clean run print from tray 1 & now it only prints 1/2 a page from top to bottom. I shook cartridge installed again turned the...
Dumb question. Did you pull the strip from the toner cartidge? OEM or aftermarket? I would try the old cartidge and see if it changes if you don't have the old cartridge anymore I would contemplate replacing the one you just purchased or taking it back to where you purchased it and get an exchange for a defective cartridge.
Feb 10, 2011 | HP LaserJet 2840 Printer
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Epson Stylus NX515 All-In-One InkJet Printer Logo
417 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
