Question about Kenmore Microwave Ovens
I have a Kenmore countertop microwave that is almost ten years old. I was using it one day, heard a pop and it quit. Could it be a fuse and how do I get the back off?
  • Kenmore Master
  • 3,740 Answers
Usually when you hear a pop during operation and it quits either the Power Diode or High Voltage Capacitor has failed. When they fail they usally also cause the internal 15 Amp fues to fail. The back comes off by removing the 4 screws (2 on each side) and 6 screws in the back. (UNPLUGGED!) The you slide the cabinet cover back about 1/2 inch.. lift the rear of the cover 30 deg and remove the cover by pulling to the rear of the unit.
Once inside take a bladed screwdriver and short across the capacitor at least 3 times just incase it was not the failure. If you don't do this and the Cap is good it can really ruin your day! Then isolate the Cap by removing the set of terminal connections tht includes the power diode connection. Use an analog meter on R x 10K and probe the cap terminals. You should see resistance then watch the resistance increase to infinity. Reverse the leads and watch for the same indication....resistance then increase to infinity. It should do this each time you reverse the leads. To check the diode you read both ways with the meter leads across the diode. One way will read ZERO ohms and the other way should read close to infinity. (You have to reverse the leads.) Like I said usually the Cap or the diode fails. Make sure you check the fuse for continuity also. Most of the time they fail when one of the 2 components above fail. DO NOT replace the fuse until you replace the failed part. Otherwise the fuse will fail again.
The fuse is located in the fuse block at the end of the power cord.
When your reinstall the cover make sure you ensure the front side locking tabs near the bottom front are engaged with the front of the internal chassis.
Thanks for choosing FixYa.
Kelly
Kelly
Posted on Sep 04, 2010
My microwave sparks while running
better quit using it till you have a service man check it out .
Mar 04, 2015 | Kenmore 1.6 cu. ft. Countertop Microwave...
How to disassemble a kenmore elile microwave
Got a model number? Is this an over-the-range (OTR) microwave oven or a countertop microwave? It makes quite a difference. Also, why do you want to "disassemble" the microwave? Do you want to get to the control board, replace a lightbulb, replace a fuse, replace the turntable motor, or replace the magnetron?
Oct 19, 2014 | Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Microwave pops fuse replaced fuse came on but hit start it makes a loud pop again and blows fuse
If this is a newer model under 7 years old, the problem is in the magnetron or the inverter board, cost to repair in either case would be excessive.
Sep 05, 2012 | Kenmore Microwave Ovens
I was heating my tea and I heard a loud pop and the unit turned off...I thought I had blown a fuse and went out and checked fuse box..flipped all fuses and microwave still not turning on at all...micorwave...
The description you provide indicates the magnetron has failed, "heats food" and blown the main fuse in the microwave oven, since the unit is 10 years old it is much cheaper to replace with a new one rather than have it repaired.
May 15, 2011 | Amana Radarange Microwave Oven
Have Spacemaker Microwave--JVM1630WB 004. started cooking ,heard a POP!! , and it did not cook the food. smelled like burnt wires or capacitor. No fire. fuse did not blow. Any suggestions ?
I had the same thing happen to my 20 year old Frigidare microwave (it was 8 years old at the time). Same POP!, same failure. Though I'm handy with electrical, I don't mess around with the innards of a microwave. There are lethal doses of electricity stored in some capacitors even when the device is unplugged. I took mine to an appliance repair shop that works on microwaves. In my case, a high-end capacitor had blown. The repair cost me $80.00. $5.00 for the part, $75.00 for the labor. My microwave is still working 12 years later.
My solution is not pleasant. If you call a tech out to your house, his charge for labor and parts will probably be more than the cost of a new microwave. Taking it to a repair shop is cheaper, but you would want an estimate first which in itself will not be free of charge.
New microwaves have come down in price over the years. Countertop models for as little as $100.00. Over the range models starting at about $250.00.
Whatever you decide, this is going to cost you some money. Your microwave is dead. Good luck and hope I've helped a bit.
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Heard a loud pop. was wondering if it blew a fuse and how to replace it ?
There is a fuse under the cover, but replacing it might not solve your problem. If a fuse blows, there won't be any power to the oven at all. You don't say one way or the other, so I don't know if there is any sign of life. If the display is lit, the fuse is still good and changing it is unnecessary. If the oven is completely dead, the fuse is likely blown but the problem will be more than just the bad fuse.
You mentioned a loud pop, which is usually not a good thing. This is normally because some component has failed, causing the fuse to blow. In most cases this part is the magnetron tube, which is the microwave source. Other parts can go bad as well, but the magnetron is very common.
It's possible to troubleshoot and repair a microwave oven, but they are dangerous devices to work on. Lethal voltages are exposed with the cover off, and improper repairs can lead to excessive microwave leakage. It's best to have a professional check the oven and give an estimate for the repair if you want to keep it. It might be more economical to replace the oven, though. They are quite inexpensive now (in my area, a 900-watt Emerson countertop model was on sale for $40 last week), so you might wind up spending more on parts and labor than you would on a new oven.
Still, if you want to try replacing the fuse, just be careful not to touch any connections and MAKE SURE YOU HAVE THE OVEN UNPLUGGED before you do anything. I don't think any special screws are used on this model, although some ovens have tamper-resistant screws to discourage people from opening them. If you run into those, drivers are commonly available now.
Good luck, and thanks for using Fixya!
Dec 04, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Lost heat on microwave ,everything else works fine simple fix?
Inexpensive fix yes, but quite dangerous as you have to either replace the High voltage Diode or the magnetron depending on what has gone. Most often it is the Diode as that is fed a few thousand volts and anomolies such as a surge in current cause it to blow(popping sound) You can also check the fuses and if lucky it is just a fuse, but a fuse very seldomly just blows as it points to an underlying fault such as magnetron , capacitor or Diode. Have a service man attend to it unless you know what you are doing as you are dealing with lethal voltages and current even after the microwave has been switched off.
Aug 01, 2009 | Kenmore Microwave Ovens
I have a DCS Model MO-24SS. The other day I was
Main fuse is under outer cover Its a large ceramic fuse and costs about $30
Jul 25, 2009 | DCS MO-24-SS Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
