Question about Lexmark X1150 All-In-One InkJet Printer
Pictures coming out yellow
My printer LEXMARK X1150 will not print like it use to. I have changed the ink,but the photo comes out mostly yellow.
    Scholar:
  • 46 Answers
The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
Without Removing Anything
There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
( Dont worry , The paper will absorb the minute amount of water being dispersed.)
If that fails you should remove the print head cartridge most are pretty easy ,
LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
http://www.fixya.com/support/t181337-piece_fallen_out_printer
Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
Posted on May 26, 2008
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
Just change ink with a new one. my pictures are coming out dull, i've cleaned it, aligned it and it hasn't helped.
go to your pc's control panel. go to printers and search for you printer. once you find it right click and go to printer preferences. since you want to print photos select the photo printing option and now your pictures will come out great.
Jun 27, 2010 | Lexmark P350 InkJet Photo Printer
When I print ther is no ink printing the paper printer window vis
click onto the Lexmark tab you have in your computer and run dianogstics on it to clean the print head. Now if any printer has ran out of ink and left not used for more than one day the head must be cleaned first with denatured alcohol
Jun 06, 2010 | Lexmark X1150 All-In-One InkJet Printer
My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
Apr 06, 2010 | Lexmark X1150 All-In-One InkJet Printer
I just changed my cartridges for my lexmark x1150 and my blues are now showing pink.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | Lexmark X1150 All-In-One InkJet Printer
Printing is faded
You may be low on ink/toner. Does the unit have a supplies status monitor or configuration page?
Have you recently changed the ink cart?
May 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
Lexmark x1150 everything works great but....
use this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:386:0:0&framed=&docid=ENUS23202&relevance=1
Feb 21, 2008 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
169 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
