Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
My badger 5 plus in sink erator is not working
  • 43,501 Answers
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Posted on Sep 23, 2010
How to Dismantle an Under the Sink Garbage Disposal
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
Sep 14, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have the Badger 5 in sink erator under sink food disposer and it is leaking from a small on the bottom of the unit. How can I repair the unit?
Disposal is rusted out and needs to be replaced.
If you plug the hole, the motor compartment will fill with water and short out the electric.
I wrote ez replacement steps from when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
HOW TO FIX MY LEAKY SINK STRAINER THATS CONNECTED TO A BADGER 5 1/2 HP IN-SINK-ERATOR THANKS FOR ANY HELP REALLY APPRECIATED
You have to take it apart and re-apply plumber's putty ... some specialize sink materials require different type of sealer, but stainless and porcelain use regular plumbers putty from hardware or home center.
I wrote EZ to follow steps that cover sink strainer basket leaking:
Feb 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator( 5 horsepower) doesnot function
On the bottom of the disposal is a place for an allen wrench. Take and turn the unit with the allen wrench to break it loose. It sounds as if has something sticking the blades.
Jun 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
1,008 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
