Question about KitchenAid Microwave Ovens
I had a plastic liner that sticks to the inside door of my microwave. It keeps on coming off and we always put it back on and it sticks. Is this an insulator or just packaging.
5 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven replacing plastic film on inside of door
FSP stands for "Factory Service Parts" which I believe was originally terminology from Amana, which now (along with several other brands such as Electrolux, Frigidaire, Jenn-Air, Kitchen Aid, Litton, Roper, and Whirlpool) is now under the Maytag umbrella.
Confusing, eh??
Hopefully the new one will have adhesive included. If not, then you'll have two sheets to use to get it right.
In that case, I'd probably recommend the spray-on type adhesive you can find at hardware stores or big box stores such as Wal-Mart, Home Depot, Lowe's etc. It will probably be made by 3M.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Cleaning inside of microwave door
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 12, 2009
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
Sep 30, 2014 | Panasonic NN-H965 Microwave Oven
How do I replace the door?
The door comes in parts not the whole door. All you have to do is remove the plastic liner around the glass and you can get to the screws that hold the door in place. Go to sears web site and you can order the parts thru them they are pretty good about getting the parts for you
May 23, 2014 | LG LMV1630ST Microwave Oven
Hi, i have a dirty window , have cleaned both sides without touching it. think its between the glass and the liner. can' find my manual. can i take the bake of the door glass off some way to clean...
Hello, Thank You for using FixYa. I will be helping you today. It is hard to take apart without breaking it! It is held together with all plastic clips and they break! But you can by putting a putty knife in the inside door seam all the way around and pry the clips down to pop the door apart.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Jenn-Air JMV8196 Microwave Oven
Hi, the button to open the door not working properly, I am able to press the button in but it is not releasing the door. what should we do?
This sounds like the door release may have broken (duh!) It may be that a peice of plastic has broken or maybe a spring has come off.
It may be an idea to have a quick look inside the microwave to see if you can see any broken parts near the door release... in some cases it is possible to re-glue broken plastic. Do not use super glue as this will not hold plastics properly, you need "evo stik - hard plastic adhesive" for this job.
BE VERY CAREFULL WHEN GOING INSIDE YOUR MICROWAVE! not only does it contain lethal voltages (even when turned off and unplugged), but if you do not put it back together properly you could have microwave leakage which is not good.
Given the prices of microwaves these days it may be nearly as cheap to buy a new one as pay a microwave expert to fix yours.
Mar 06, 2011 | Microwave Ovens
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Inside table always coming off track when sliding back and forth
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You probably have a bad turntable coupler or support.
Feb 01, 2009 | Kenmore 63792 Microwave Oven
IN CABINET MICROWAVE
Hello JudyKitz,
That mesh is there to protect the user and acts as a shield to contain microwave energy to the cooking compartment. Never compromise that material.. You can purchase replacment liners at this site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130353 If you prefer, you can get a thin piece or sheet plastic cut to fit at many local hardware stores or home centers..You may want to make a paper template or take accurate measurements with you for that method.. Hope this helps you..
Oct 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
