Question about Samsung 941BW LCD Monitor
Flickers for several minutes at start up - Samsung 941BW LCD Monitor
  • 11,361 Answers
It may have dying power supply due to bad DC filter caps in the power supply, it will get worst and more damages may occur.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 05, 2010
Monitor screen rolls and flickers periodically for several seconds to a few minutes
Check if the System is installing updates or any other hidden program this might lead to screen flickering
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
Sep 26, 2012 | Dell 1704FPVs 17" TFT LCD Flat Panel...
When switching on my PC the LG L1900R monitor Flickers badly for about five minutes then works correctly..Are there any Known problems with this Monitor.. It's about 3 years old Thanks
The flickering is caused by parts called capacitors in the power supply failing. These parts help filter the power supply and when they start to fail they allow voltage fluctuations to pass through and this causes the flickering. If you can solder then you should be able to do the repair yourself. We have several guide posted on our web site at: www.ccl-la.com look in the monitor repair section. Open your monitor and replace all of the capacitors that have bulging tops and you should be bak going again. If you have any questions contact us through our web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 10, 2010 | Computers & Internet
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
It recently started flickering when I turn it on. It did this for several minutes before displaying normally. Then it wouldn't display anything at all until I turned it on and off several times. Then it...
duffy325, Don't mess with it!!! Get SAMSUNG to give you a new or REFURBISHED unit t0 replace your BAD unit. Your unit is behaving like I would expect a 3-5 year old unit. It's got a power supply problem, not a front panel switch gone bad problem. FYI also visit YOUTUBE for the longer video clips of "LCD monitor disassembly" and "LCD monitor repair" to find out some common KNOWN failure mechanisims why they fail!! You will be amazed! With your unit's behavior I suspect a "flakly backlight or SMPS/INVERTER" problem. bye for now. If this was of some help, do rate this response on fixya. 12fixlouie
Nov 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung 941BW LCD Monitor Logo
125 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
