Question about Husqvarna 28cc Gas Line Trimmer
Need to know how to wind trimmer line on trimmer
    Problem Solver:
  • 11 Answers
Depends on the trimmer, all heads are different. However, the majority of trimmers are wound as follows:
1. pop the top cover off the head, pull the spool out. It will be either single or double lined, they will be wound counter clock wise.
2. the end of each line goes out each of the seperate holes
3. slide spool back on and replace cover
www.ButlerPower.com
Posted on Sep 06, 2010
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Need to change the weedeater line.
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Sep 29, 2010 | Homelite Mighty Lite Lawn Trimmer
I inherited a Ryobi 14'' Electro Hornet, but do not know how to change the trimmer line - can you help?
Jim
Nov 29, 2009 | Ryobi Garden
Stihl fs trimmer line fitting how to fit line to trimmer can you help anyone
If you need more help, let me know.
Jim
Nov 20, 2009 | Garden
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
Jim
Oct 25, 2009 | Garden
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Don't know how to install new string on Echo SRM 2400
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
I have a weedeater brand weedeater and need to know how to take the spool off so I can wind more line on it?
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Jun 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Husqvarna 28cc Gas Line Trimmer Logo
262 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
