Question about Craftsman Garden
I'm looking for a carb linkage diagram for a Briggs & Stratton rotory lawnmower engine. Aspring fell off mine and I can't see where it should go.
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
  • 4 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
computerscot is right. This engine is not designed to run slower than a few hundred RPM below maximum. The carb has a built-in fuel pump that only operates properly at relatively high speed. Your motor probably has either missing or weak throttle springs which will lower the RPM. Replace them and adjust the tension so that the speed is up. For a diagram of the carb and springs, check the Briggs & Stratton online user manual maintenence section. Look for file "briggsandstrattonMS5373-GB.pdf".
Posted on Oct 30, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
rycgl
  • 1545 Answers
SOURCE: briggs and stratton 6.5 intek runs only if i keep
Drain the gas. Remove the aluminum float bowl on the carburetor. Dont lose the exterior washer. Clean the brass bolt very well that hold the bowl on...paying very close attention to the small holes near the top of the bolt. Use no metal objects to clean this brass bolt as it also functions as the main jet to the carburetor. If you clean it till it is nice and shiny and reinstall it (not TOO tight) then your fuel flow problem may be resolved. Hint: Install an inline fuel filter.
Posted on May 17, 2011
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
I need to find free diagram for linkage hookup on a 10 HP Briggs & Stratton Snapper riding lawnmower
I would go to mytractorforum.com, click on the word 'forum' just to the right of the tractor wheel, and scroll down to the small engines and repair section. Inside 'stickies' is a directory of B&S service manuals.
Apr 14, 2013 | Snapper Garden
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Garden Logo
27 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
