Question about GE Lands Phones
My GE 25865GE3-A cordless system with two additional side units seem to be unable to communicat any longer. I have installed new batteries in all of the units. "Out of Range" low battery , won't register etc." all come up. Could the main sending unit need repaired? Thomas R Hawkins 724-981-0240 t.r.hawkins@roadrunner.com
    Genius:
  • 1,478 Answers
I will advice you try reset the unit, Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Posted on Sep 04, 2010
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
I need a user manual for my GE 25865 5.8G cordless
25865EE1:
http://www.home-electronics.net/ge/pc/IB/25865EE1_IB.pdf
25865GE3:
http://www.home-electronics.net/ge/pc/IB/25865GE3_IB.PDF
Jul 29, 2011 | Uniden Cordless Phone
Ge dect 6.0 cordless...When I use the phone it only lasts about 10 min, then starts beeping, ..Low battery?
The rechargeable battery pack needs to be replaced, it is at a point it can no longer hold a sufficient charge.
Jan 16, 2011 | GE Lands Phones
I have a cordless GE phone 5.8 gig and the ringer is turned off. i can't figure out how to turn it on
CLICK HERE for your owners manual in PDF format.
Page 15 explains the procedure for the base ringer.
For a handset only - you can use the volume up/down. Your selection is High Medium Low and OFF.
Select the level and press DONE to confirm.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 28, 2009 | GE 25865GE3 Phone
Battery died and or charging system failure
I think its probably your only choice, NIMH batteries are known to have a very short shelf life if not regular charged / discharged you can get GE cordless batteries here - GE Cordless battery
Jan 10, 2009 | Uniden Cordless Phone
Answering switched to handsets
is the phone totally/fully charged
Nov 26, 2008 | Lands Phones
Unable to dial out
This is wild, tomorrow's post today. Check the phone to see if it is in pluse or tone. Try changing that. Is this a cordless phone or a cell phone? If you changed a cordless phone batterie chech to make sure the new batterie plug is the same color as the old one. Some are black and some are white and the polarity is opposite.
Feb 13, 2008 | GE Cordless Phone 900 MHz
GE handset registration?
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
Lands Phones Logo
167 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
