Question about Weber Spirit SP-310 Propane Grill
I have a Weber spirit 3 burner grill. It's about three years old. If I turn on gas at regulator, no problem. Once I turn on gas at grill and then light the grill, I begin to smell gas. I've taken off the grilling grates and the diffusers, so I can see the burners. They are all lit. I've inspected the hose, and it seems to be in good condition. I've sprayed it and just about everything else with soapy water and I don't see any gas escapiing. The only thing that looks slightly abnormal is that the rear burner is burning a little less high, and a little bluer than the two front burners. Otherwise, everything looks ok.
  • Weber Master
  • 2,398 Answers
Did you check round the burner control knobs
Posted on Apr 13, 2017
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
  • 9 Answers
SOURCE: I need directions for using a weber grill
Open the bottom vent, open the top vent. Start your charcoal in a chimney starter (my favorite way). Dump in the burning charcoal. Wipe down grill grate with canola or other high temp oil. Place grate on grill, cover, set top and bottom vents to desired temp. Cook food. Cleanup.
Posted on Jul 07, 2009
  • 139 Answers
SOURCE: Where can I purchase a kit to convert a Weber
Online look up Atlanta Grill Service they will have it!
Posted on Oct 18, 2009
cadesertmax
  • 274 Answers
SOURCE: Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Posted on Jan 10, 2010
  • 15 Answers
SOURCE: New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Posted on Apr 16, 2010
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
I have a Weber Spirit E-210 and the temp will not rise above 300. I cleaned the burners and still an issue. Does the Regulator need to be replaced?
The regulator may need to be replaced. But, before you do, follow the directions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY, SLOWLY
(Slow motion, slow).
3. Once the tank valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and does the flame height look correct for being in the highest setting?
If so, light the remaining burners the same way. Now, did all the burners light and do the flame
heights all look correct for being on the highest setting? If so, you may have solved the problem.
4. Close the grill's Hood/Lid and allow it to heat for at least 20 minutes. At that point is the
thermometer registering higher than 300 degrees or quickly heading in that direction?
If so, you did solve the problem! Remember to always open the tank valve very, very slowly.
if that didn't solve the problem, you'll need to replace the grill's Hose/Regulator Assembly. You can get one at any home center or hardware store that sells grills and accessories for about $30.00.
Take you old one with you for comparison purposes.
Hope the helped you troubleshoot and solve the problem. Please let me know & Happy Grilling!!
Jun 20, 2011 | Weber Spirit SP-310 Propane Grill
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 03, 2010 | Weber SPIRIT E-210 (NG)
Low flame & heat - Cleaned all tubes, replaced regulator
Close the air vent on the burners to get more flame if that does not work you have a bad thermostat!
Jul 06, 2010 | Weber Spirit? E-310 Propane Grill
Gas smell when in use only.
you have a gas leak could be spilt burners needs to be fixed or new grill
May 10, 2010 | Weber Q Grill
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
My Weber gas grill is less than a year old. The
gas regulator make sure all burners are off when you connect bottle... the units have a leak sensor and will stop the gas coming out because it thinks you have a leak when you connected the bottle. now try hooking up the bottle again with all the burners closed incl. the side burner and the infa red. It will work o.k. then
Apr 07, 2010 | Weber 3820301 Gas Grill
Dec 20, 2009 | Weber Genesis Silver B Grill
The temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Weber Spirit SP-310 Propane Grill Logo
187 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
