Question about Vacuums
How to fix a garbage disposal - Vacuums
  • 377 Answers
Depends on what is wrong with it. Two basic problems that can exist - Circuit breaker can be tripped Blades can be caught up.
Unplug unit and re-set breaker on bottom of unit. Get an appropriate size allen wrench and insert into bottom of unit and manually turn chopper blades. Remove allen wrench, plug in and start unit up.
Posted on Sep 05, 2010
  • pwillitz Sep 05, 2010
    If your GD is plugged into a GFI outlet under the sink, you may have to reset the outlet breaker by pushing the appropriate switch on the outlet itself.
How to take apart model 3601a
Shark products are disposable. There is no fixing them. Throw it away
Oct 29, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Fix the automatic cord winder
Start by trying to blow it out with compressed air. It's probably clogged up with garbage. Might need to open the case and clean it out
Oct 08, 2014 | Electrolux Epic 6500 Vacuum
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
My neato is showing a message 'my vision was blocked. Please press ok (3000)'. How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Sep 20, 2013 | Neato Vacuums
Garbage disposer model GFC520F silently hums but not spinning
Hi! It sounds like one of your blades is jammed on something. Easy to fix! Make sure the garbage disposer is switched off (not necessary to unplug). Any large wooden handle tool (not a wooden spoon or plastic broom-they snap..1 to 1 1/2 inch diameter) axe handle, wooden broom ect., put the handle into the bottom garbage disposer on an angle. get nthe handle against the bottom and side where they come together. With gentle pressure, rotate the wooden handle until you feel it stop. This will be a blade..there are usually 2 at opposite sides inside there. Push against it till you feel it break loose in a clockwise direction. Once forced loose it should run again. Whatever jammed it will still be in there so you can to grind it up but it's advised to look with a flashlight and locate and remove the object. FYI...if your disposer is ever non-responsive, there is a red button either on the bottom or back of the disposer. This is a re-set button. Good to know. Let me know if you still have problems. Hope this fixes it for you!
Sep 05, 2011 | Vacuums
Where do the wires go when i am wiring a garbage disposal using a tw o pole toggle switch
The garbage disposal shoud have three wires a green wire goes to ground,
the white wire is neutral, and the black wire is your hot. at the switch, the white
neutral wire feeds straight to the garbage disposal as does the ground, many
times the switch will either have two screws one gold and one silver and the
green is designated as ground. hot goes to the gold screw and the black wire
coming from your disposal goes to the other screw. make sure to turn off power
before working on electrical wires check with voltage meter, its not like working
on your car, if shocked it can be fatal, if unsure handle wires with insulated tools
or gloves. good luck!
Jun 26, 2011 | Vacuums
Suction is gone have cleaned out all areas that can be cleaned out????is it garbage
Is it "garbage"? Not necessarily.
If you're really happy with the vacuum so far, and the motor sounds nice and smooth, it would be worth your while taking it to a service center for a tune-up.
That all depends on the price of a suitable replacement, of course.
May 23, 2011 | Bissell 6594 PowerForce Bagless Upright...
Bionaire humidifier model:bcm7309cm How to clean the air filters?
"You should change your furnace filter once a month in the winter season and your central air filter once a month during summer months.
If you run your heat or air every day and night, have pets, or your home collects a large amount of dust, you may need to change your filter more often during very hot and very cold months.
If you use disposable filters, it's really not worth vacuuming them to reuse them. They are inexpensive enough that you should replace them instead.
Disposable filters don't work as well after only being vacuumed and they are usually in a cardboard frame and therefore don't wash well.
Before you take out the filter, however, vacuum the outside and around the filter encasement. After you remove the filter, you should vacuum behind it, too, to catch any stray dust and particles.
Replace disposable filters with new ones."
(http://www.mrscleanusa.com/en/cleaning-tips/tip/cleaning-air-filters.html)
Mar 03, 2011 | Vacuums
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
