My desktop computer has a double monitor. Last night, I was experimenting on a monitor cable and replaced the one with the digital display without turning it off. When I have connected the cable, the monitor won't work anymore and it keeps on going to sleep mode as if the computer is off. The computer seems not to recognize the monitor any longer and when I go to Drivers at the Control Panel, it only shows me single display. What do I need to do? Thanks.
  • Manny Aquino Sep 04, 2010
    If I use the vga connector on the dead monitor, it works. It is when I switch it to digital that it does not respond.
  • 4,737 Answers
What if you only connect the non-working monitor after disconnecting the other?
I would suspect the Video card, if both the monitors have similar connectors, eg DVI/HDMI, the first connect the dead monitor on the working port or vice versa. That'll reveal the truth. If it's working, then the problem is with your Graphics card, you'll need to replace it.
If it's not working then, hook it up on another computer. I hope it has multiple ports, if so switch the ports, suppose if you are connecting it through the DVI port then try VGA or HDMI or the other way.
(First of all, try to find out the culprit and start troubleshooting)
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
Posted on Sep 04, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 04, 2010
    One more question, does the other monitor has digital port on it? If so give it a try.
    To troubleshoot this issue properly, you'll need another cable (spare), so please keep it ready and try with both the monitors on the DVI port.
    Good luck.
I need help in my computer, last night my computer's screen color is normal but today i start my computer so its screen color has been changed in green .. so tell me how it has chaged and now wat do to do?...
This can happen dur to the following reasons
1. Monitor cable that is connected to the tower may be loose, disconnect it and reseat it properly.
2. Monitor cable is damaged, please check if the cable is pressed against some thing and damaged, if so you can detach the monitor cable and buy a new cable.
3. Monitor is faulty, the color functionality electronics is bad, this can be rectified by a monitor service personnel.
4. Display card is faulty (onboard or add on), to check if this is not the scenario - Disconnect the monitor from the tower and turn of the monitor and the switch it on you should be seeing colored bars, if the colours are looking good then the monitor is fine and the display card is faulty.
Please check the above steps one by one and reply to this post in case you are unable to narrow down the cause. Thank you for contacting Fixya.
Feb 04, 2011 | Computers & Internet
Tip
Tips for Troubleshooting Power Problems with Laptops
If you experience shadow/double images of text, icons, etc. on your computer's display, the first thing to check in this case is the connection between your graphics adapter socket & your display monitor. You have to make sure that this connection is not loose & that the cable connecting your computer to the display monitor is not damaged or is not running very close to a source of electromagnetic interference.
on Dec 01, 2009 | Computers & Internet
I cannot get my Toshiba Satellite M305-S4910 to switch its' display to a stationary monitor. Is there something I need to do besides plug in the monitor cable?
Are you in windows 7? If so, hold the windows key and press P. Select the monitor output configuration you want (being careful to make sure you can still see the screen on something).
If you lose the screen entirely, unplug the vga cable and reboot the computer.
May 26, 2010 | Toshiba Satellite M305-S4826 Laptop
No pic on monitor. connected everything to computer and no picture on the monitor
Please double check, you should have two cables out of the monitor and connected.
1. The power cable to your UPS/ AC switch. 2. display cable connected to the CPU(main box).
Based on the information you gave one or both of these cables are not connected/switched on.
Thanks.
Feb 03, 2010 | E-Machines eMonster 550 PC Desktop
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Rainbow colors on the display , comes in gradually and covers whole screen after booting up ok to windows desktop...cannot see past the pixils....
Hi, this sound like the resolution on the monitor is too (Low); go to: Contol Panel, click Display Settings. Ajust the resolution to the High position; also down-arrow Highest Colors: 32Bits etc. Thanks paul7of9
Jan 03, 2010 | Dell Inspiron 530 Desktop Computer
I set my computer to power save mode last night by changing the setting so the monitor would turn off after 5 hours. Now I can't get it to come back on. I've tried moving the mouse, turning the monitor...
hold the power button down for 5 secounds, then turn back on . if you can get the bios load up page try pressing f12 or f8 constantly untill u get a menu to boot computer in safe mode and try tunring this power saving off and restart.
Nov 29, 2009 | Sony VAIO Digital Studio PCV-RZ24G PC...
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Desktop monitor
Hi
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Dec 31, 2007 | Compaq Presario 5BW284 (202493-003) PC...
Computers & Internet Logo
David Payne
David Payne
