No Power on my 61z886 tv
Had tv only 3 months used. I bought a new bulb for it but, that wasn't the problem. When plugged in no lights what so ever comes on. I checked the fans and they turn freely. When unplugged and plugged back in you can hear 2 clicking sounds but that's it. What's wrong with it???
  • 4,234 Answers
If the set is only 3 months old, it is under warranty. Place the old bulb back in to the unit and return it for warranty exchange or repair. Basically the set is going into shutdown because a problem was detected inside. This is done to prevent further damage. This will be covered under warranty.
Dan
Posted on May 12, 2008
TV was on then suddenly shut off...now will not light up to show it has power and will not work at all. Just bought this less than a month old.
check the LCD bulb it is located at the top and bottom of the LCD monitor maybe it is defective or maybe the power supply of the bulb is also defective.Replace the bulb or the power supply you can use the power supply of a cathode light that is usually use in motor cycles
Jul 22, 2011 | Coby TFDVD2495 LCD TVDVD Combo
Just change the bulb few month ago and the screen in the lower center starting to get dark working it way up to the top
Hi, did you make sure it was the right lamp the reason is that theres two types of lamp one that shoots the light wider and another that concentrates on the center.Also check the ballast the main power of the bulb it comes to happen that when u put in a new bulb the ballast is not able to provide enough power to light up the whole screen.
Apr 18, 2011 | JVC HD-61Z886 61" Rear Projection HDTV
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
How to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Light bulbs burn out after a few days in garage door opener, craftsman 1/2 HP double lights. have used every kind out there, specially made for garage doors, etc.
Try REVEAL brand DOUBLE LIFE ceiling fan light bulbs, available from HOME DEPOT. The filament in those bulbs is much thicker than any others, and the one I installed on my own Sears GDO has lasted 3 months so far, compared to one week for others I have tried.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
