Question about Homelite Mighty Lite Lawn Trimmer
Operators manual Homelite ST385BC - Homelite Mighty Lite Lawn Trimmer
    President:
  • Homelite Master
  • 1,545 Answers
You can try: http://www.manualsonline.com/
Of course their user manual downloads are free.
Posted on Sep 05, 2010
  • Raymond Pelling
    Raymond Pelling Jun 25, 2017
    Don't happen to have it as of 6-25-2017.
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: How to replace pull chord on a homelite
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on Dec 14, 2010
I need a manual for Homelite Texron #105064
I found this download link for the Homelite chainsaw ut10506-4 parts manual, if it is helpful.
http://megaslides.com/doc/9405595/homelite-chain-saw-parts-manual-for-xl-chain-saw-ut-10506...
No operators manual found.
May 02, 2017 | Homelite Garden
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
Need to find where air cleaner is ?
If your unit has one, it would be in front of the carburetor. Some Ryobis and Homelite trimmers do not have an air filter on them, just a screen inside the choke cover.
Sep 08, 2011 | Homelite Mighty Lite Lawn Trimmer
Operators Manual for HOMELITE CHAINNSAW ut10946a
Here is the web address for the Homelite UT10946A Chain saw:
http://manuals.homelite.com/system/files/4644/original/ut10946A_ps06206.pdf?2011
(it will be a pdf file, if you don't have one, you will need a pdf reader. Try adobe.)
Dec 23, 2010 | Garden
I need an Operators instruction manual for a Homelite HBC26 SJ brushcutter/strimmer
hi i have a homelite hbc26 strimmer and it will only rev up if choke is almost fully on if choke is moved to run position it will only idle have cleaned carb and no better,daveywarren@live.co.uk
Aug 21, 2010 | Homelite Garden
I`m looking for the HOMELITE 410 CHAIN SAW owner`s manual
I found a parts listing here but it does not list an "Operators Manual":
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find
something that matches.
An Internet search proved fruitless. The Arboristsite (beg for manuals) thread netted no help. You might try there:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Join and post your request. There will be heat and barbs about your homeowner saw, but someone will almost certainly provide one.
I suggest you submit your request here first:
Contact us Homelite.com
https://register.homelite.com/contact_us/new
I suspect they will provide a pdf file for your saw, free of charge.
I am sorry i was not more helpful but it was not for lack of trying. If you do find a source please reply back so I may provide a better answer in the future. Good Luck
Lou
Jan 22, 2010 | Homelite Garden
Spark plug gap on homelite 16 inch ranger chainshaw
I don't have access to an Operator's Manual and they don't appear to be available on line, I checked several different Homelite models at Chain Saw Collectors Corner. All said 0.025". HTH
Lou
Oct 11, 2009 | Homelite Garden
Need owner or service or both manuals for Homelite Super 2 16" chainsaw UT# 10654, SN HJ0110214
I haven't found a location of the operator's manuals but the numbers you provided made the IPL (exploded parts list) easy. Thank You. Go here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; In the "Model Name/Number" type in "UT-10654" and you are there.
Atta boy/girl
Lou
Sep 23, 2009 | Homelite Garden
Need an operation manual for my Homelite Versatool
Problem solving still pending.
K.F. Cheong
Aug 24, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
1,443 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
