Question about POLARIS 480 HEAD AND HOSE
Replacing the belts that drive the two wheels - both belts are broken - how do I replace them ?
  • 990 Answers
I have been in the business for close to forty years and can walk you through the whole process but I have found you have to go to the pool store to get the parts. While your there they will do this for you and just charge for the parts. Also they will go over the whole head to see why the belts wore out.That way they don't just change part's but fix the problem also.
Posted on Sep 04, 2010
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Hard to turn steering wheel
Check your drive belts. Possible loose or broken off.
Dec 23, 2013 | 2002 Nissan Altima
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
Won't knead dough
Chances are that your drive belt is broken. With the pan and paddle removed from the oven and your machine unplugged turn it on its side so the bottom is facing you. Hopefully it has one of the removable metal panels on the bottom. If it does, remove that panel using a screwdriver. When the panel is off see if the drive belt that runs between the 2 pulley wheels is broken. If it is broken remove the old belt and look for a number on the side of the belt that looks something like this STS 60 S3M471 I sell replacement belts for bread machines. Contact me through my website breadmachineshelp.com if you are interested in replacing your drive belt. Thanks, Daryl
Again the website is breadmachineshelp.com or just email me at daryl441@msn.com
Mar 05, 2013 | Kitchen Appliances - Others
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
My whirlpool washer does not spin, i open it up today and notice the belt on the spin wheel is twisted and around the wheel but not connect to the shaft. please help.
You will need to remove the belt and replace with a new belt. If the belt is broken kindly get the same type with the dimensions for replacement.
Place the belt on the drive wheel and run it over the motor pulley and manually turn it on so as to fit it into the slot.
Feb 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Change drive belt on converter
dear atv owner there is no need to remove the pulleys to replace the drive belt. you must open the large pulley by hand and drop the new belt in bottom of this pulley this will hold it open then pull the belt across to engine pulley then turn the rear wheels in clockwise direction this should force the belt on the engine pulley job done jim
Mar 29, 2009 | 1998 kawasaki KLX 300
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Need to change tumble belt
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Jun 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Changing the Drive belt
How do I replace the drive belt on a zanussi TD265? any help
Oct 28, 2007 | Dryers
POLARIS 480 HEAD AND HOSE Logo
174 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
