Question about John Deere Garden
Leaking seal on axle shaft to rear wheel on a z245 jd zero turn mower
warlock61
  • 659 Answers
SOURCE: Rear Axle Leak
if it is the seal, you will have to remove the caliper and rotor, remove the differential cover and remove the bolt and pin inside the diff carrier housing. push in the axle and remove the axle clip and pull out the axle use a seal puller or prybar to remove seal reverse the steps to assemble
Posted on Dec 10, 2008
EarthJam
  • 23 Answers
SOURCE: removal of rear wheel on cox stockman ride on mower
These wheels are usually just held on with a Key way, ALOT OF TIME they offer resistance because they are rusted insode the rim and are needing a mallet to hit them from the inside pretty hard.
Turn it as you can usually a lever on the back side of the mower can be pulled out without the brake on to slip the transmission into nuetral. Turn the tire. I have used a small peice of 2x4 as well because a hammer dont fit well. Good luck I will watch this post and search my Diagrams to see if i have this rider tmrw at work.!
Posted on Feb 03, 2009
  • 51 Answers
SOURCE: Left rear axle seal is leaking differental oil.
ok then here is the procedure  1 take off the axle nut
2 on the lower control arm you will find a large nut and bolt i belive the nut is a 21mm and the bolt side is an 18mm. this bolt is the one at the knuckle near the brakes. remove it
3 you will need to pull the knuckle out of the way or a helper to pull the knuckle out of the way so you can slip the axle out of the knuckle.( its a tight fit but there is room to slip it out.)
4 use a pry bar to pop the axle free of the diff. hosing its held in by a spring clip make sure the clip comes out with the axle if it gets stuck inside you will have to fish it out.
5 use a pry bar or screwdriver to pry seal out of housing then use a flat object that contacts the entire rim of the new seal so it can evenly be installed with out getting smashed and tap it in with a hammer. ( a good trick here is to use some grease and pack it into the new seal where the spring is this will prevent the spring from being shocked out of the seal during instalation . the spring keeps tension on the rubber in the seal so it stays tight to the shaft it is sealing.)
6 then revers the above steps. also make sure you are using the right gear lube it will most likely be 75w-140 but make sure you check your owners manual will tell you if it doesnt say on the diff cover. you can cause a lot of damage if you put in the wrong thing. and make sure  you feel the axle spring clip snap into place.
as a note there are two types of axle seals that are used on these so if the new seal looks different than the old seal then the folliowing will be important to you.the seals on these have been redesigned so if you axle has what looks like a cup or dust cover pressed onto the shaft where it goes into the diff the new style does not use this and it will prevent the axle form going in all the way so the spring clip will not lock in and you will have a leak. so you will have to remove it and install the axle without it.
Posted on Mar 22, 2009
  • 335 Answers
SOURCE: REAR AXLE SEAL LEAKING ONTO BRAKE SHOES NEED INSTRUCTIONS ON HOW TO FIX
Jack up vehicle and support on stands. Remove wheels. Remove differential cover . Locate and remove lock pin that holds cross shaft in. Slide cross shaft out. Push axle inward to release axle c clip. Remove axle and pry out old seal. Install new seal with proper tool.Add some lube to the seal lip to aid axle intallation. Revese removal procedure. This is for a "c" type axle.
Another type has 4 nuts attaching a retainer plate to the backing plate behind the axle flange. In this case the 4 nuts are removed and the axle will come out. This may require a little effort. I think that you have a "c" type axle in your vehicle. Hope this helps. Moe
Posted on Apr 28, 2009
  • 187 Answers
SOURCE: Rear differential / axle noise and vibration.
A drive shaft that has lost a balancing weight will vibrate between 40 and 50 mph. If not corrected this could damage the input shaft bearing and seal on the differential causing oil leakage. Differentials are fairly indestructible but if run without oil will fail.
As for the front end you should never run the 4wd on dry pavement. The front differential is a posi traction unit that will turn both wheels at the same rate unlike the rear diff that will allow the inner wheel to turn slower than the outer on turns.
Posted on May 08, 2009
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
2003 gmc sierra 2500 hd axial seal leaks
not enough detail for what end the leak is at. Front sounds strange for a pickup unless 4 wheel drive and then if the style is open shaft behind the brake rotor this would require dissemble of a few more things. If from the rear,which is the common repair, this is from a worn axle bearing on the axle shaft,which causes wear to the rear axle seal either located on the shaft before the bearing to the outside. Or the second option can be a axle seal located in the end of the axle housing. when you remove the axle shaft you would be looking at the end of the housing tube and see this seal. On older models ( My younger days ) they would also install one on the inner side of the housing next to the Gear Unit in the center of housing, ( also known as the PIG Unit ).need further info....
Jun 05, 2013 | Cars & Trucks
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            Mar 21, 2010 | 1998 Mercury Mountaineer
                                                            1994 buick roadmaster, oil leaking out of right rear axle, checked brake fluid is full, could it be differential oil leak @ end of axle??
                                                            If what you see leaking is very oily and does not evaporate, likely it is an axle seal. If there are no leaks in the brake system, that's the only thing back there that can leak. If the axle bearing is going away, it can damage the seal so make sure you look for small shiny metal flakes behind the seal when you replace it or you will be doing the job again very soon. Can't remember...that IS rear wheel drive right?
                                                            Dec 01, 2009 | 1994 Buick Roadmaster
                                                            How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
                                                            Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
                                                            Removal
                                                            sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
                                                            1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
                                                            1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
                                                            1. Drain rear axle lubricant by removing the axle housing cover .
                                                            1. Remove differential pinion shaft lock pin and differential pinion shaft .
                                                            1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
                                                            1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
                                                            Installation
                                                            NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
                                                            sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
                                                            1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
                                                            1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
                                                            1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
                                                              NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
                                                              sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
                                                            1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
                                                            1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
                                                            1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
                                                            1. Install rear disc brake caliper and rear disc brake rotor .
                                                            1. Install wheels and tires.
                                                            1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
                                                              Rear Disc Brake Caliper Anchor Plate
                                                            1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
                                                            1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
                                                              sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
                                                            1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
                                                            1. Install axle shafts as outlined.
                                                            May 13, 2009 | 2004 Ford Crown Victoria
                                                            Rear wheel bearing
                                                            SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
                                                            1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
                                                            1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
                                                            1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
                                                            1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
                                                            1. Remove the differential pinion shaft (4211).
                                                              1. Remove the differential pinion shaft lock bolt (4241).
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
                                                              Remove the U-washer (4N237).
                                                              1. Push the axle shafts (4234) inboard.
                                                              1. Remove the U-washer.
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
                                                              Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
                                                              Remove the axle shaft.
                                                            Rear Wheel Bearing and Axle Shaft Oil Seal Removal
                                                            1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
                                                            1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
                                                            Installation
                                                            1. Lubricate the new rear wheel bearing with the specified lubricant.
                                                            1. Using the special tools, install the new rear wheel bearing.
                                                            1. Lubricate the lip of the new wheel bearing oil seal.
                                                            1. Using the special tools, install the new wheel bearing oil seal.
                                                            1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
                                                            Installation
                                                            1. Lubricate the lip of the wheel bearing oil seal
                                                              Install the U-washer.
                                                              1. Position the two U-washers on the button end of the axle shaft.
                                                              1. Pull the axle shaft outward.
                                                            1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
                                                              1. Align the hole in the differential pinion shaft with the case lock bolt hole.
                                                              1. Install a new differential pinion shaft lock bolt.
                                                            1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
                                                            1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
                                                            1. Install the rear brakes. For additional information, refer to Section 206-04 .
                                                            1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
                                                            1. Lower the vehicle.
                                                            Apr 10, 2009 | 2004 Ford GT
                                                            Leaking rear axel seal
                                                            1. Remove or disconnect the following:
                                                              Rear wheel Brake caliper and rotor, if equipped Brake drum, if equipped Axle retainer nuts Axle shaft, seal and bearing assembly
                                                            2. Split the bearing retainer with a chisel and remove the retainer ring.
                                                            3. Press the bearing off the axle shaft.
                                                            4. Remove the axle seal and retaining plate.
                                                            0900c15280220349.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Rear axle seal and bearing components-2002-05 exc. 2005 Grand Cherokee Hope this helps, please dont forget to rate my solution.
                                                            Lefty64
                                                            Apr 09, 2009 | 2002 Jeep Grand Cherokee
                                                            Replace left rear axle seal 1999 ford explorer
                                                            Axle Shaft Removal
                                                            1. Remove the differential housing cover (4033).
                                                              1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
                                                              1. Remove the bolts.
                                                              1. Remove the differential housing cover.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
                                                            2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
                                                            3. Remove the U-washer (4N237).
                                                            4. Push the axle shaft inboard.
                                                            5. Remove the U-washer.
                                                            2. Install the differential pinion shaft lock bolt finger-tight.
                                                            3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
                                                            Seal Removal
                                                            1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
                                                              NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
                                                            6c7eb46.gif Installation
                                                              • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
                                                              • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
                                                            1. Using the special tools, install the rear wheel bearing.
                                                            1. Using the special tools, install the wheel bearing oil seal.
                                                            Feb 22, 2009 | 1999 Isuzu Rodeo
                                                            Garden Logo
                                                            50 people viewed this question
                                                            Top John Deere Garden Experts
                                                            Phil Walker
                                                            Phil Walker
                                                            Tim Whalen
                                                            Matt Olenzek
                                                            Matt Olenzek
                                                            Are you a John Deere Garden Expert? Answer questions, earn points and help others
