Question about Kenmore Elite HE4 Electric Dryer
Will not run, not lights on panel, have power, drum light on
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Light inside works no power to panel
I didn't READ any fault in the machine?! It is "just" the Light remains on? Typically, when the dryer ends it's cycle as a safety feature the light will remain in the ON position for a brief period of time. The reason you get no working functions is because the safety feature is disallowing any unauthorized entry in the drum (Kids). The feature usually can be shut off by reading the owners manual. It can not be reset by unplugging the machine! That is the default setting
Apr 06, 2014 | GE DBVH512EFWW Dryer
Toner light on, replaced toner cartridge, won't print, toner light still on, replaced with new cartridge, toner light still on and won't print.
unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Oct 30, 2008 | Brother Office Equipment & Supplies
One of the indicator lights stays on
HP LaserJet 2550L Printer panel indicates 4 LED's for 4 toner cartridges, 1LED for the Drum unit. one LED for the power on button. one of the cartridges or the Drum unit has a problem, it indicates from the lights shows on or flashing. By referring to the indication lights you can diagnose the problem contains in one of the cartridges or the drum unit. By replacing the appropriate item you'll be able to make the printer to the working condition.
Jan 24, 2013 | HP LaserJet 2550L Printer
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
My printer drum light is lit and will not copy. I have put in a new drum and the is still lit and will not copy
Hi
Please follow the bellow instruction…
Open the front panel.
Remove the toner and the drum.
Remove the toner from the drum.
On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them.
Put everything as it was.
Turn on your printer.
Now, the low toner light should be gone and the green light should be on.
Now, you can empty your cartridge.
If the Drum light is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side.
Pres the control panel button until all lights are lit, and then release it.
The Drum counter is now reset.
Thanks for contacting fixya.com
Feb 02, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
Drum light works - contol lights don't/can't start dryer.
Either the machine control, or the user interface. Further diagnosis isn't possible. I'd try the machine control first. It's just under the top panel, along the left side.
Feb 06, 2008 | Whirlpool GEW9250 Electric Dryer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Kenmore Elite HE4 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
