Question about Kodak EasyShare Z740 Digital Camera
When i put a new memory card in, the camera reads "memory card needs formatting", but when i click format, it does nothing
  • kakima Sep 04, 2010
    What type and size memory card?
  • nattypooh200 Sep 04, 2010
    Kodak SDHC 4GB. states on the back of the packaging that its compatible with Kodak Easyshare...
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
While some Easyshare cameras will use SDHC cards, the documentation for the Z740 states that it uses MMC and SD cards.
Try using an SD card. If that works, then stay with SD cards. If that doesn't, then there's something else wrong.
Posted on Sep 04, 2010
4 Suggested Answers
SOURCE: I cannot format my brand new memory card in my Kodak Easyshare.
Believe the 4 GB card is too large for this camera and internal camera software was not designed to format or manage so much memory.. try a fast SD under 2 GB.
Posted on Jun 04, 2009
  • 102366 Answers
SOURCE: I just inserted a 8
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Posted on Sep 30, 2010
Testimonial: "You are correct k_akima, I my new card is a SDHC 8GB and will not work. I did not know there were different kinds of cards. Thanks!"
  • 661 Answers
SOURCE: in sert SD card turn
Hi halestone26,
I would like to help you out with this problem ,
Please follow the below instructions :-
  1. Make sure that your remove the memory card out of the camera and connect it to your PC via a card reader.
  2. After you connect the memory card , to your pc via a card reader , you should get a removable drive icon relevant to your memory card in your my computer folder.
  3. Then all you need to do , is select format by right clicking on the card , and then when you see the options in format dialog box you need to select the NTFS and FAT32 one at a time and format the memory card and then check if it works with NTFS file system in your memory card or FAT32 file system.
  4. Unless your memory card is damaged , the above solution works 90% of the times.
Hope this helps ..:) Your feed back would be appreciated.
Posted on Jun 21, 2011
In sert SD card turn on camera. screan shows Memory card refquires formatting, continue and stills reads card needs formatting. put new card in and does the same. Camera does not read card always say card...
Hi halestone26,
Jun 21, 2011 | Kodak EasyShare DX4530 Digital Camera
Hi, Our daughter has a Samsung ES30 12.2 megapixel camera. I just put a new sd card in and it says Card Error, When you click on OK, it tells you to 1. Turn the camera off and on again, 2. remove and...
You need to format the card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer. Right click over the removable disk and then click format. It will format the memory card.
Then insert the memory card into the camera. Now the camera will not show the error message.
Hope this helps.
Shane
Apr 04, 2011 | Cameras
My old memory card all of a sudden reads unusable, So i bought a new one...and it still says unusable... what do i do? I have only had the camera for 4 months
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
Dec 20, 2010 | Kodak EasyShare C142 Digital Camera
I wud like 2 format another memory card in my qv-r61 but wen i put the card in i can get nothing onscreen to set it up any ideas? it is a Fuji memory card and when put in the camera all i have got onscreen...
Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is.
Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
let me know if you need further assistance ok
Jul 02, 2010 | Casio QV-R61 Digital Camera
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
My memory card is unreadable. I insert it into both of my cameras and into my computer and they all say the format is wrong and they won't read it.
plug your memory card into your computer
go to my computer right click on the memory card then click format.
Maybe one of your cameras have a format function on them, go to settings and it might be in advanced or memory then click format.
oops i accidently put this in clarification... dumb computer locked up and changed it...
Sep 27, 2009 | SanDisk Electronics - Others
I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
The I would have to say bad card. Do you have another to try?
May 11, 2009 | Kodak EasyShare C360 Digital Camera
Foramtting scandisk
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Dec 29, 2008 | SanDisk 2GB microSD Memory Card
Bought a new memory card and camera wont read it
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Apr 20, 2007 | Sharp VE-CG40U Digital Camera
    Kodak EasyShare Z740 Digital Camera Logo
    381 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Jerry Greenberg
    Jerry Greenberg
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
