Question about Kenmore HE2 Plus Front Load Washer
Flashes F21 when its time to drain then wont drain and stops.
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump is being obstructed by debris or some other foreign object as opposed to being faulty, although that can`t be ruled out...yet.
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the drain hose, hose from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
macmarkus :)
Posted on Sep 04, 2010
  • superpimp Sep 10, 2010
    This worked perfectly, I found three socks and over a dozen small bolts caught in the filter. After cleaning it all out my washer is working again, thank you for thre great advice and step by step directions.
  • Mark MacDonald
    Mark MacDonald Sep 11, 2010
    Awesome, glad I could help.
    Thanks again for using FixYa, spread the word.
    Regards,
    Macmarkus :)
Whirpool frount load washer flashes F21
F21 means long drain time. Check filter and plumbing.
Aug 04, 2011 | Washing Machines
My machine will not finish load. it flashes the f21.. i unplug it it goes to 85 minutes. i reset it to rinse and spin. remove the 2nd rinse. sometimes it goes through sometimes it doesn't and goes back...
The F21 error code is displayed when the water didn't drain in the normal time,the usual reason the washer did nto drain with in the normal time is because the filter screen on the pump is clogged. This tip i wrote will show ya how to take apart the washer and clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Mar 29, 2011 | Kenmore HE2 Plus Front Load Washer
Washer stops and flashes F21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
Door wont open f21 alarm
F21 indicates that the washer is having problems draining. Check the drain hose to see if it is kinked or if there is an obstruction in the hose.
SUD comes on every time excessive suds are detected. Not using the proper detergent will set this off faithfully. The machine will run a cycle to remove the excessive suds before completing the wash cycle.
You need to clean the drain filter by removing the 3 screws in the bottom of the front panel. Then you will see a white twist cap. Remove the filter and clean it out.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Front load Kenmore Washer 3 years old. Stops in the midde of any cycle and flashes F21 on the display screen
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 22, 2009 | Kenmore Washing Machines
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops in the middle and flashes F21?
Hi and welcome to FixYa,
An F21 error code indicate drain problem. Might you want to inspect/clean the drain system from the filter to catch basin to impeller, pump/valve and drain hose. To do this, the bottom/kick panel ahs to be removed. A bit of a messy job so pls be prepared with paper towels and other absorbent materials.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
