Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Whirlpool dryer is not completely drying my clothes, appears to be getting overheated. Any suggestions
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Whirlpool Dryer GEW9200LW1 skip digits when set to dry
If the clothing comes out dry within a normal time,usually 40 minutes or less. Whats happening is the computer is recatulacting the time remaining to dry a load of clothes as it senses they may still not completly dry or even will drop off some time if clotes are dry before time computer calculated at start of cycle.
Gene
Aug 16, 2011 | Whirlpool GEW9200L Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
My whirlpool duet dryer doesn't get my clothes completely dry. We have replaced the sensor and checked all the ducts. I still have the same problem. Any other suggestions?
Try washing the lint filter in hot water and detergent to remove fabric softener deposits that block air flow. Hope this helps!
Jan 18, 2010 | Dryers
Dryer stopped, will not restart. Overheated.
you need chek :
1-bushin motor
2-bushin drum.
Oct 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Electric dryer cuts off when it gets hot
I assume you mean it completely shuts off. If the motor switch or belt switch were bad the dryer wouldn't start at all. the 2 thermal fuse are not resettable so they cannot correct themselves either. sounds like the motor overheating, this could be due to poor airflow.
usually caused by a poor vent system (non metallic or many elbows), or a bad motor. If motor squeals after 10 or 15 minutes (or less) it is likely bad. occasionally an old lint filter becomes clogged if you use dryer sheets, pour water on it and see if it holds in the filter. if so it should be replaced. you could scrub it in hot soapy water as a temporary fix or test.
Jun 08, 2008 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
