Question about HP Office Equipment & Supplies
How to make a hp color laserjet 3550 print duplex !!!
    Genius:
  • 1,478 Answers
Firstly, find out if your printer supports duplex printing, refer to your printer manual or look for the Two-sided (Duplex printing) or Print on both sides drop-down menu in the Printer Properties dialog box on your PC (sometimes found in the Printer Shortcuts tab). If you can’t locate any of these options in your printer manual or Printer Properties dialog box, you may not have driver support for duplexing or automatic duplexing
To make your printer print duplex, follow the steps below, Step 1: Go to your PC’s Print dialog box and click on Properties.
Step 2: Click on the Printing Shortcuts tab, and select Two-sided (Duplex) Printing from the drop-down menu.
Step 3: Select Automatic from the Print on both sides drop-down menu. Click ok, and you are set.
Posted on Sep 04, 2010
5 Suggested Answers
  • 75 Answers
SOURCE: my HP Color Laserjet 3550 Printer wont print black
go through the menu on the printer ,there is a setting where it can be set to continue printing when the toner is out.
Posted on May 10, 2010
  • 903 Answers
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
Posted on Jun 09, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: HP 3550 color laserjet smears
Ghosting is usually a sign that the fuser in the printer needs to be replaced. Remove the fuser and look at it. If the rollers are not smooth and free of built up toner or other gunk then replace it. Supplies for this printer have gotten much more affordable and if the printer works fine otherwise it is a good investment to replace the fuser.
Posted on Mar 12, 2011
ErusTownsend
  • 592 Answers
SOURCE: How can I print to
If Hp does not have a drivr to support it then you are out of luck unless you find someone that hacked drivers to work with it. If they have Windows Vista drivers, you can try those but they are not goign to guarantee to work.
not all equipment from Xp works with vista or 7. Xp is not the same OS or even same breed as Vista/7
Posted on Apr 22, 2011
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
May 11, 2010 | HP Color Laserjet 3550 Printer
If you chose: Print in GreyScale, the printer will be forced into Monochrome mode. This is available in the Printer Properties. However, I do not know if this will work on this printer. I have seen it work with other manufacturer's printers (mostly inkjets).
I hope this helps.
Mar 29, 2010 | HP Color Laserjet 3550 Printer
My HP Color Laserjet 3550 Printer wont print black when it is out of color ink
Mar 19, 2010 | HP Color Laserjet 3550 Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
Jan 20, 2009 | HP Color LaserJet 2600n Printer
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3550
install the latest version of dirvers from www.hp.com, and change the settings where paper source is automatic. that all problem solves. feel free to mail me
Jan 15, 2007 | HP Color Laserjet 3550 Printer
560 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
