Question about Sampo PD 80A (Gray) 17 in. Flat Panel LCD Monitor
Monitor sampo PD-80A Software or driver setup for y monitor
  • 385 Answers
Free after free registration at drivers.com. also probably available at the manufacturer's website.
Posted on Sep 04, 2010
When my computer starts its display driver does not work but after some time when windows starts it works correctly
Possible that PC is hanging up as there is fault on the OS ( operating system) . So open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Jul 26, 2011 | Sampo PD-70 15" Flat Panel LCD Monitor
I can not adjust the computer nonitor Sampo PD70FA using the XP operating system pack 2 on a card onboard Nvidia Geforce 6150SE The computer changes the settings so that the plug monitor to 800x600...
Open the System control panel, click on Hardware and open Device Manager. Check both the Video Adapter and Monitor items to see what kind of hardware is identified. If both are identified correctly, right-click on each and select "Properties" to find out what driver version is being used. If you get a "generic" driver, that is your problem. In that case, you'll first need to be sure your video card's driver is up to date - this may take care of the monitor problem. The monitor should support either 800x600 or 1024x768 resolution. One limitation, if you have onboard video, is you may not have enough shared RAM allocated to video use to provide for the higher resolution setting. You can adjust this in the BIOS on startup - set shared video RAM to the maximum amount. Be aware that this memory is not available for your programs and if you don't have a lot of RAM installed you may take a big performance hit because you'll be using virtual memory (hard drive space) more often.
Is there a reason why you are still using Service Pack 2? If you have adequate RAM (768 MB or more) and keep Automatic Updates disabled, SP 3 offers better performance and security. Also, newer driver versions are written with the assumption you are running SP3. Also, Microsoft often provides the newest drivers for name-brand hardware in their Windows Updates Optional Updates - this is easier than going to each vendor and searching their support and downloads pages. (You are no doubt aware that if you have Automatic Updates disabled you should keep a regular schedule for manually visiting Windows Updates - Microsoft is stuck in a defensive war with hackers and virus writers, and all Windows users are targets for the attackers.)
May 25, 2011 | Sampo PD-70 15" Flat Panel LCD Monitor
The sampo alphascan 411 has not picture the screen is black. Turns on but no picture.
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 11, 2010 | Sampo AlphaScan 411 Monitor
Need user manual for Sampo 15'' lcd monitor - PD-70FA-16T
Hi, Anita.
Here's a link to Softpedia's Sampo Driver pack:
http://drivers.softpedia.com/get/MONITOR/SAMPO/Sampo-LCD-Driver-Pack.shtml
Select the smaller icon "Download".
Hope this helps.
Aug 03, 2009 | Sampo Computers & Internet
Need display driver for sampo P7011MS
http://drivers.softpedia.com/get/MONITOR/SAMPO/Sampo-CRT-Driver-Pack.shtml
Aug 02, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Sampo Monitor warranty
Warranty contact information is here:
http://www.sampo.com.tw/english/Support/supprot_online.asp
Sep 09, 2008 | Sampo Computers & Internet
Touch Screen Montior
Do have the 3M driver? If not you can go to their web sight and down load it. You'll need to know what touch card you have, Microtouch or Dynapro. The monitor will be marked hopefully or you could call tech support. Just google 3m touch screen drivers.
Aug 13, 2008 | Sampo PD-70 15" Flat Panel LCD Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Sampo LCD PD-80A monitor screen blinks on and off every 4...
I just replaced the relay on my second-hand NEC2010X . It would go out after some period of time, but come back if I unplugged it and then plugged it in again. It finally died altogether, but when I replaced the relay, it worked fine. Apparently this relay is the weak link on many LCD's (probably the only moving part in the whole thing). So open it up, unsolder the relay, and put in a new one.
Dec 24, 2007 | Elo 1724L (Dark Gray) 17 in. Flat Panel...
Sampo PD 80A (Gray) 17 in. Flat Panel LCD Monitor Logo
323 people viewed this question
Top Sampo Computers & Internet Experts
Paul Bade
michael galang
Are you a Sampo Computer and Internet Expert? Answer questions, earn points and help others
