Braun 9595CC Electric Shaver Logo
lori molloy Posted on Sep 04, 2010
Hi my husbands shaver fell in water accidently and although it worked initially he can't get it to work. So now what?
Why no display on screen?
The display show on your cell phone is not working and should be replaced.
Aug 22, 2021 • Cell Phones
Hi i have a huawei y220 it fell in water and now it charges but does not want to be on what must i do
ufortunately in the user manual for your phone there are safety lists once a phone like yours is in conditions such as water damage or any other on the list, the phone will not work properly, what i can suggest if you are on a warrenty and the warrenty has not expired yet, get ahold of the company and tell them you accidently dropped your phone in water and need a replacement.
Aug 13, 2014 • Cell Phones
I accidently droped the mp3 player in water and its not comming on the charging bar keeps on going from full to empty rapidly and the buttons are not working.
electronics that have been dropped in water should be taken apart immediately, allowed to try with a fan on them for 2 or so days, reassembled and then attempt to charge. If this doesn't work- sorry, but it's toast.
Camera fell in water initially turned on after
water and cameras do not mix unless they are designed for underwater use.
2helpful
2answers
A challenge dehumidifier not collecting water
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
1helpful
Springs fell out
I did get it fixed. I kept looking at it and studying it and I finally figured out that the small, gold head is where they had to go. I pushed on it and it finally fell out. I saw two small holes that looked like they were the same size as the springs. I put them in and when I put the piece back in the razor, the spring lined up with 2 small pegs on the inside. I snapped the head in place and the gold bars then moved up and down with a little resistence. I turned the shaver on and it worked just fine.
2helpful
My shaver head broke! PLEASE HELP ME!
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
