Question about Samsung Televison & Video
Have Model Code LNT4061FX/XAA Serial No. AHBA3CSPB286150 Version CN06. When trying to turn the TV on it clicks on and off and on and off What is the problem; what is the solution??
Three capacitors on the motherboard are bad. They cost about 2 dollars each. If you are handy, you can take the tv apart and replace them. It took me about 30 minutes. Unplug the tv. Lay it on a large table so the stand can hang off without tilting the tv with the back of the tv facing up. take all the Phillips screws off the back cover. Take the back cover off. There is a grey cover about the size of 8x11 inches on the left middle area held on by about 6 to 8 phillips screws. Take it off. Unplug the motherboard, there are about 5 different plugs. Unscrew it and take it out. There are 3 somewhat swelled 1000mf 10v capacitors in the upper area of the motherboard. Replace them with 1000mf 16v capacitors, soldering required. Make sure you install them with the ground in the proper hole. Put it all back together and you are fixed for less than ten dollars. Samsung should be doing this for free. It really makes me mad that they can put out such an expensive product and not accept responsibility for a potential fire hazard. I will make sure anyone who wants my opinion about an electrical product knows how bad samsung is. Good luck.
Posted on Sep 04, 2010
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
I have a Samsung LNT4061FX/XAA HDTV. It is taking a long time to turn on and its clicking when u push the power button until it finally turns on. I was thinking it is a relay or a switch, possibly the...
Power supply board,have dead capacitors,they bulges up or bust open.U have a soldering iron,solders,solders witchs,u know how to solders?U know basic electronic.Check the power supply board for these defective capacitors replaced these capacitors.Will get ur power back correctly.Or tries websites Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 20, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
I have a Samsung LNT4061FX/XAA Serial no. AHBA3CSPA03617J. The TV will not turn on. It just continues to Click and the Red light in the front goes on and off. Is there a part available to fix this problem?
Regarding the problem with LNT406FX/XAA models not powering up - I contacted Samsung @ 1-800Samsung and they issued a repair tag and put me in touch with a repair company that came out the next day and replaced the capacitors on the power supply. Apparently Samsung got a batch of bad capacitors from a supplier and they know which TVs by the serial numbers. My TV was 28 months old and there was no charge. TV works fine now. Good for Samsung for acknowledging they had bad parts for and getting the tv fixed at no charge.
Aug 17, 2009 | Samsung Televison & Video
I have a Model LNT4061FX/XAA, Ser # AHBA3CSPB07786R, Version CN06 LCD TV. It is 18 months old and I have started to have a problem with turning the set on. When I press the on button it sounds as if it...
You Need To Do A factor Reset If You Are Getting A screen Go to Settings and look for factory reset that should help you get it back up !!remember that factory settings will lose all setting you originally had !!
We Are Here To Help!!
Aug 25, 2017 | Samsung Televison & Video
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LNT4061fx does not turn on
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Nov 20, 2008 | Samsung TXG2547 25" TV
Televison & Video Logo
662 people viewed this question
Henry  Thomas
Henry Thomas
