I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes it for 30 secs & stopping & starting the dvd sometimes helps temporarily some DVDs start OK but get progressively worse. VERY annoying. Help appreciated.
Click Here
You can set the delay times for audio playback to correct 'Lip-sync' error caused by delayed video.
  1. Press the AUDIO SYNC button on the remote control
  2. Within five seconds, use the VOL +/- to set the audio output delay times (0–150 ms).
    If the volume control is not used within five seconds, it resumes normal volume control function.
Posted on May 15, 2009
  • 476 Answers
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
Posted on May 13, 2008
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Dec 21, 2010 | Philips HTS-3565 Theater System
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
Im unable to play HD DVD on my philips HTS8100 home theatre system
As far as I can see your philips dvd player is not a HD-DVD player.
It just upscales standard dvd or digital content to HD ready televisions.
Jan 14, 2008 | Televison & Video
Not playing voice but playing music/surround
sounds like you may have a dodgy scart lead.check that none of the pins are loose/damaged. Also check the sound settings on the tv, it may have reset itself to the default sound setting. Or it might just be the audio settings on your dvd player have been adjusted,almost all dvd movies have there own audio adjustments.
Jan 13, 2008 | Audio Players & Recorders
Hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
http://www.consumer.philips.com/consumer/en/in/consumer/cc/_productid_HTS9800W_55_IN_CONSUMER/DVD-SACD-Home-Theater-System+HTS9800W-55
though yours is a high end set, but its not HD disc compatiable.
Regards
Benam
Nov 14, 2007 | Philips Cineos HTS9800W System
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
