My oil light is still on after adding oil - Computers & Internet
  • 385 Answers
If it's full and still on, it's likely the oil pressure sending unit, usually a one wire, screw in, ofter circular unit near the oil filter. occasionally in the engine block.
Posted on Sep 04, 2010
Nissan Ad Wagon 2007, cars is service regularly on time, just did a oil change after a week, the oil light indicator start appearing while driving..... once car is in D, 2nd & 1st and stationary n
re check your oil to see that there was enough oil put in, look for any oil leaks under the car while running , and shut off. If no oil leaking , and the level is ok, I'd say your oil pump may be getting weak
Apr 07, 2014 | 2007 Nissan Tiida 1.6
2005 Mazda 6 oil light came on added oil light still on could this be the oil pump
The oil light means that the oil pressure is low. If the car is serviced regularly and the oil filter is not blocked, it will be the pump. Or the oil pressure sensor itself is faulty. Be very careful, driving a car with no oil pressure will kill your engine very quickly.
Mar 28, 2014 | Mazda MAZDA6 Cars & Trucks
My Check Ingine light came on for three days. When i checked the oil it was low. After adding oil the next day the light was off. Is this normal for a 2000 isuzi rodeo Ls 4 wheel drive?
Yes it is,it worked,light came on,you added oil, light when out.Now why are we having to add oil.Got a leak or it's burning it up.Check oil drain plug.Check filter.Do you have oil stains under your parking space?
Feb 07, 2013 | Cars & Trucks
Reset service engine soon light on 2005 Buick LeSabre
disconect battery wait 5 minutes reconect after 3rd time driveing light will reset itself
Jan 19, 2013 | 2005 Buick LeSabre
2000 Mitsubishi eclipse the oil light came on and my car shut down. I added 1 quart of oil and it was full but the car still won't start.
The oil light does not indicate the car is low on oil (based on your discription) it indicates the oil pressure is low, the no start is most likely due to this low pressure and the fuel pump has been cut off to prevent damage to the engine from low oil pressure. Please have a shop locate the cause of the low oil pressure warning and repair it as needed. It could be a false light or a real one, which means if you drove it very far you may have damaged the engines bearings.
Sep 24, 2012 | Cars & Trucks
Oil light flickers. Just changed my radiator, truck runs cooler and also changed my battery (check engine light used to turn on before I started to disconnect the battery cable and reconnect it; and I...
Check the oil pressure with a mechanical test gauge and it will likely be ok, if so replace the oil pressure sending unit. Do not use any oil thickener in this engine it can damage the bearings.
May 23, 2012 | 1991 Mitsubishi Mighty Max
Oil light comes on when you hit brakes, sometimes it stayes on
Adding engine oil you said no visible leak.
Your engine has oil consumption valve ga-ides worn out also when the piston rings worn out oil passes through in to the combustion ch amer.
you said when you hit the brake oil light come on that sh owes low oil pressure.
You want to resolve the problem and you stop to adding engine oil do your engine ova howling means new piston with piston rings oil pump and engine bearing new valve guide then your engine is new no more oil to add.
thanks.
Feb 16, 2010 | 2004 Chrysler PT Cruiser
THE OIL LIGHT KEEPS COMING ON AND WHEN I ADDED 1/2 QT NOW IT IS KNOCKING REALLY BAD AND SOUNDS LIKE THE ENGINE IS GOING TO BLOW UP
you have low oil pressure, so adding oil will not cure the light, if the engine is knocking u have damaged the engine bearings and it will need to be torn down and rebuilt.
Oct 19, 2009 | 2003 Mitsubishi Montero Sport
2007 rabbit - oil light
If it was still running okay & no noise, probably no engine damage. Adding 2 quarts should have turned off the light if the problem was oil pressure. Sounds like the oil pressure sending unit may be bad.
Apr 29, 2009 | 2007 Volkswagen Rabbit
Burning oil, but dont know why
Nowdays 1 Qt. in 3000 miles, really isn't that bad, even some new vehicles claim that's normal. I know with my current vehicles, both at approx. 150,000-160,000 miles, they won't use any for first while after an oil change, but then after mileage starts adding up again, they start to use a little, approx.I Qt, every 1000 miles or so, until it's changed again. I've switched to the high mileage oil, just for piece of mind, as they say it revives seals, and has added protection for the higher mileage engines.This time around I'm thinking of adding "Lucas" & see how it works, as I've heard some pretty good reports on it, just to see if it will prolong that oil breakdown, at mid change.
Feb 06, 2009 | 1999 Pontiac Grand Prix
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
