Question about HTC TyTN Smartphone
TyTN II - Keep the phone screen alice during a call
Hi there.
I've just replaced my O2 XDA IIs with a HTC TyTN II. When I make or receive a call the phone screen blacks out completly. If I press the green answer button the screen comes back - but the call is on hold.
I have set the backlighting to remain on both on bateery and mains power - yet I still get this black screen.
It makes it impossible to key in additional number once the call has commenced.
Is this normal or is there a fix or workaround to keep the screen alive during a call?
Any ideas appreciated.
Thanks
Corpcc
  • petsaver Sep 30, 2008
    I have the same annoying problem as corpcc. It would be great if someone could send me the same file he has to resolve this problem. thanks.
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
Posted on May 12, 2008
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
I have an HTC TytnII smartphone, which was locked earlier for Orange. I have 2 questions: 1. How to load the new OS 6.5 ? 2. My mail does not show the attachments, how to bring those on ?
Hi, Go to xda-developers.com and then go to forum then look for blackstone its the code name for the kaiser HTC tytn II and then into rom and then find amongst the threads that have been posted hope this helps =) =)
Jul 18, 2009 | HTC TyTN II Smartphone
How to hard reset my o2 xda II?
To perform a full reset
A full device reset clears memory, deletes all data, and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain. All data that you have created and programs you have installed are erased.
Press and hold the Power button, and then use your stylus to press the “soft reset button” at the same time. Be sure you have backed up all your data on an SD card or on a desktop PC before performing a full reset. Hope this helps.
Jun 26, 2009 | O2 Xda IIs Pocket PC
Broken screen (o2 Xda IIs)
Try Ebay. I had a phone once that I broke the screen and went to ebay. I typed in the exact model # and looked fror touch screens. I found one and got it and replaced it and it worked fine.
Jun 22, 2009 | O2 Xda IIs Pocket PC
How to hard reset my o2 xda IIs
Hi...dis is prakash...see dear you can make hard reset of your phone by using this method
press and hold power and cemera key and soft reset button ..I have HTC touch its working ..I hope it will work on your phone also..further u can contact throuh my mail - jhunjhunda_123@rediffmail.com
May 12, 2009 | O2 Xda IIs Pocket PC
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
Cracked screen
I have replaced XDA II Mini once, for sure XDA II mini and imate jam screen is same thing, i found this step by step guide for XDA IIs
http://pdasmart.zftp.com/instructions/sx66_09.pdf
its not the 100% instructions but hope it will help you.
Jan 14, 2008 | LG KU990 Viewty
My O2 XDA IIs stoped working ....
try going to http://forum.xda-developers.com/ and searching there. they have loads of advice of the XDA IIs. Proberly need to start a fresh with it, try a hard reset as it seems your stuck in bootloader mode
Oct 05, 2007 | O2 Xda IIs Pocket PC
XDA II pocket PC manual
can download pdf version from the following link: xda.o2.co.uk/downloads/Detailed_XdaIIs_Windows_Userguide.pdf
Sep 17, 2007 | O2 Xda IIs Pocket PC
DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Feb 25, 2007 | LG 37LP1D 37 in. LCD Television
HTC TyTN Smartphone Logo
354 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
