Question about John Deere Garden
It won't stay running john deere 855. just replaced fuel pump thinking that was the problem, but it will run for a while, when you put it in gear, it dies
  • 8 Answers
SOURCE: ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
SOURCE: John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
Posted on May 23, 2009
  • 9 Answers
SOURCE: john deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Posted on Jun 22, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
2005 John Deere. Why doesn't it run?
put a new spark plug in it. i just fixed a john Deere i worked on for hours. the only thing i didn't do was replace the spark plug. after i put a new plug in it it ran like new.
Mar 12, 2016 | John Deere Garden
Have a John Deere 3020 with a Marvel-Schebler carburetor. Not staying running seems like its out of gas and it is getting fuel it runs a short wile and dies pump the fuel pump manual pump and it runs for...
Have you checked that your float is working properly in the carb? If it is sticking with the plunger shut it will block fuel inlet regardless of having fuel supply?
Have you checked to see if there is definitely fuel in the line at the carb when it's acting up?
Have you made sure that there is still spark when it quits running? You could have something that is grounding out when it warms up and makes it quit firing that while you 'fuss' with gas issues, cools enough to spark then fails again. Hard to say without more details. Also are you sure there isn't a clogged fuel filter in the tank, carb-inlet or inline somewhere?
Oct 06, 2013 | John Deere Garden
I have a 1999 John Deere LT-133 when I put it in any gear or try to engage the blade the engine won't stay running. Do you have any solutions for this?
sounds like the safety switch under the seat may be bad. unhook and / or bypass the switch. if this fixes the problem then replace the switch. hope this helps you
Aug 16, 2011 | John Deere Garden
I have a John Deere Z820A 25 Horse Kawasaki. After about 45 minutes it acts like it is running out of gas. It will start again with the choke out, but won't run for long. I have replaced fuel...
I am an ex-z820a owner because these machines are terrible. Deere issued a PIP for these motors and maybe yours has not beed done yet. The best thing to do is get with a dealer see if the PIP has been completed then sell as fast as you can. I traded my z820a on a z920a and couldnt be happier.
Jul 26, 2011 | John Deere Garden
Lt180 won't run without choke pulled out..replaced fuel pump, gas,.2 spark plugs...fuel filter looks fine & carb was replaced last year.
Hi, disassemble and clean all jets in the carby, also check the valve clearances are correct because if they too tight the engine will not draw fuel in. Hope this helps, regards Phil.
Jul 14, 2011 | John Deere Garden
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Sep 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
224 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
