Question about Sony ICD-P320 Digital Voice Recorder
It is show error assess after it was connected to PC
  • 1 more comment
  • irinaz1949 Sep 11, 2010
    sorry, it was after it was disconnected from PC
    it happened after recorder was d/c from PC not after it was connected
  • irinaz1949 Sep 13, 2010
    it says:error assess after i d/c it from PC
  • 2,973 Answers
Irinaz,
There is a set procedure to disconnect from the PC. You have to use the procedure where you disable the device first and then Windows tells you "It is safe to disconnect the device now". It is safe only after that to disconnect the device. If not done so then the device may go bad. Remove the battery from your recorder and after a minute reinsert and then power on the recorder. If it still does not work, then I am afraid that the recorder may have got busted while removing from the PC.
Posted on Sep 13, 2010
    President:
  • 2,777 Answers
On the screen of the Sony unit it displayed error? Did it have any error code with it (usually a series of numbers, letters, or combination of both).
So you are unable to access any files on the unit, is that correct? And you used to be able to in the recent past?
Posted on Sep 12, 2010
  • Sony Master
  • 17,970 Answers
I suggets reinstall all sofwtware drivers and firmware in the pc and try again.
Keep updates.
Posted on Sep 11, 2010
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Erorr 2000-0146 in hard vostro 1050
source/original from dell community
Welcome to Dell Community.
Let me first appreciate the fact that you have tried the steps yourself to isolate the problem.
Error code: 2000-0146 (DST Log contains previous errors) refers to previous errors in the hard drive which might not really be a hardware failure. In order to confirm this, I recommend you to run a custom test on the Hard drive which takes longer time than the Pre-boot System Assessment which you have already performed on the computer but it will give the accurate result.
Once the Pre-boot System Assessment is completed, the computer will give you an option to "Run the remaining memory test", please select "No". Then the computer will launch the 32-bit Diagnostics from the utility partition (if available).
After the diagnostics is launched, in the main menu, please click on "Custom Test", then select the "Hard drive" and click on "Run Tests". If the test completes without any error then the hard drive is fine and PC Restore can be performed to restore the computer back to the factory condition (which will result in data loss).
Please refer to the following article for more information on running the Dell 32-bit Diagnostics Utility: http://dell.to/MNJv4B
If you have any further questions feel free to reply.
Nov 28, 2013 | Dell Computers & Internet
Dropped my laptop
If the laptop appears to run with a black screen, hook a spare monitor to the video output, if picture okay screen may need to be changed, check cable connections and the inverter board under the screen for cracks. If both screens show the same symptoms it is the video graphics card or the motherboard itself, if the laptop is completely dead it is the main board and needs to be assessed.
Jun 04, 2012 | Sony VAIO Computers & Internet
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
Dell inspiron wont boot windows..I have ran a pre boot system assessment build 4118... I am getting the error code 0142. msg error code 2000- 0142 please help
That error is normally a bad hard drive. Replacement is fairly easy and not to expensive, but you will have to reinstall a Operating System to the new drive.
Jan 27, 2011 | Dell Computers & Internet
Im trying connect my phone to pc but not connecting hot to connect phone to pc
hi, does your phone have space for usb cable? if yes, you will need to get a cable connect it to that port and connect the other one at that port where you normally plug your flash on the pc. try check your computer and locate your external memory or removable drive. but not you will only be able to assess features or things stored on the memory card alone.
Jul 14, 2010 | Samsung Cell Phones
Not connecting to pc
Yes u can.... connect ur cell to PC and select option "file transfer mode"... but in this case ur phone will be switched off and will restart again. And you will not b able to access ur phone.
Apr 10, 2010 | Sony Ericsson W200i Cellular Phone
Disc read error occoured
This can occur as a result of any unreadable drive that is in your boot sequence not reading. Remove all media from the machine(CD, DVD, Memory Card, Flash Drive, Floppy Disk, Printer with memory card slots), then try booting again.
If that doesn't work, chances are your hard drive is damaged. It may only be minor logical damage or could be serious hardware damage. That is more difficult to assess via subjective analysis but could be sent to a pro for assessment if you have files you require on the drive which are not backed up.
If this is the case and you do not have anything important on the drive or if you have your files backed up on a second source simply replace the drive and re-install your operating system, then restore the backed up files and move forward.
If you require any additional info or advice, just ask
Chris
May 17, 2009 | Acer Aspire M3641 Dual Core E2200 PC...
ThinkPad R40 2897 lost all internet. No Wireless, No Ethernet No
check the device driver status of network adopters in device manager .if it shows any error then reinstall the device drivers again.
if you are using WI-FI then reinstall the drivers of your wireless device.
and don't forgot to reboot your system after doing so.
if the problem exsist then contact your ISP.
they will provide the settings if any and i hope you are able to apply setting for the internet connections.
Apr 26, 2009 | IBM ThinkPad R40 2897 Notebook
Sony ICD-P320 Digital Voice Recorder Logo
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
