Question about Exercise & Fitness
What would cause my treadmill to speed up and slow down on its own?
  • 16 Answers
SOURCE: treadmill goes normal speed until I get on it and
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
Posted on Jun 29, 2009
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
  • 13 Answers
SOURCE: Treadmill won't slow down
if you look at the front roller. there will be a black device that has two wires. this is your speed sensor. Make sure it is facing the magnet on the roller.
Posted on Aug 10, 2009
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
bwinton
  • 83 Answers
SOURCE: It will speed up and slow down
This is caused by one of four problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. The fourth problem is that the lower board either needs to be adjusted or is going bad, I cannot be for sure without knowing the brand and model. Let me know if you have any questions.
Posted on Apr 30, 2010
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Sole F65 does not slow down
Your treadmill may be defective as delivered. Check with the point of purchase for advice.
Dec 21, 2013 | Exercise & Fitness
Cybex 530t treadmill speed slows down intermittently anyone help
Please LUBE deck belt + rollers bearing too
2) test the input voltage motor, if there are the motor need repair.
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 17, 2012 | Cybex 530T Pro Plus Treadmill
My treadmill work fine when i turn it on but when i step on it the blet. slows down to crawl.
What make/model is the treadmill? What speed does this behavior occur? Does the walking belt slip, while the motor and rollers continue to turn? If the walking belt is slipping then the motor belt needs to be tightened. If the walking belt slows with your weight on it, does this happen at 1-3 mph and still occur at 4-5 mph? It could be your body weight causing it to slowdown, try to increase the speed to 4 or 5 and see if it still happens. If so, is the treadmill rated for your body weight? Please be more specific.
Feb 08, 2011 | Exercise & Fitness
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
Treadmill slows down Free Spirit Mod.#122300800
make sure you are not in a program. Can you speed it back up?
Feb 05, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
408 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
