Question about Kenmore HE2 Plus Front Load Washer
My Kenmore HE 2 Plus front loading washer will not drain the water, after spin cycle. Currently no error code, or lights. Clothes are still soaked. Previously the machine indicated a "sd" error. I then removed the bottom panel, to inspect the round filter thingy. It was filled with gunk. Cleaned that out, re assembled. Ran the washer on clean mode. Then tried a load. . Will not drain.Please help
    President:
  • 1,554 Answers
Since the filter is cleared, check to make sure that the drain hose is not clogged or kinked. Remove the filter again and reach the pump impeller in with your finger to check if turning freely or not. Replace the pump if the impeller is stuck.
Check the pump during the drain step of the cycle to see if it's working or not. Check the pump wire connections both at the pump itself and at the central control unit (CCU). Remove the top panel to access the pump connections at the central control unit (CCU).
Posted on Sep 04, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore 24032\24036 Top Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
151 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
