Question about Motorola Mobility RAZR V3m Cellular Phone
Bluetooth not working
I've tried turning the bluetooth setting off and then back on. Tried restarting the phone. Tried clicking on the "Find Me" feature and the phone still can't find my Motorola H500 earpiece.  I also had it set up to connect with iSync on my PowerBook and MacBook Pro, and now it doesn't work either
Any ideas?
  • MacGeek May 13, 2008
    Another alternative is that if you recently installed an SD card, try removing it and see if bluetooth starts working.  I've had a couple Moto phones (one KRZR/K1m and one RAZR/V3m) where the bluetooth stopped working if there was an SD card present.
    Genius:
  • 2,035 Answers
The blue tooth port is defective on your phone you need get it replaced from a service center............................
good luck........
Posted on May 12, 2008
My iHome iBT60 has a low volume when connected through Bluetooth. I've tried connecting & reconnecting it twice, and it didn't work. Has anybody had success troubleshooting thi
Turn up the volume on your iPhone. Also, try connecting your iPhone or any other media player, e.g. computer, to the AUX IN jack on the speaker and see if the volume is higher for that connection.
Jan 01, 2015 | iHome iBT60 Bluetooth Rechargeable Mini...
Can't get my iPhone 4S to pair up via Bluetooth with the headset tried the instructions but does not seem to work
1. Turn on your bluetooth and make sure that it's not connected to other devices.
2. Put the Bluetooth in seeking mode(searching for devices)
3. Go to your iphone and go to settings, General, Bluetooth and turn it on.
4. Once your phone picks up the Bluetooth click it. Then it will then ask you for a 4 digit pass code. Standard ones are 1234 or 0000.
5. If that still doesn't work try turning off your Bluetooth and then turn it back on holding the power button. This will allow it to restart and start again. (this is what I did for mine) then repeat the process again.
Hope this helps.
Oct 22, 2012 | Lands Phones
My bluetooth doesn't switch on
nokia 3310 does not provide bluetooth
Mar 01, 2012 | Nokia 3310 Cellular Phone
Im trying to use PDAnet with bluetooth I have the bluetooth card installed on my laptop tuning vista, and it has an error that says that I need to install the bluetooth software for the phone, and I've...
Make sure you have bluetooth on on both, and that you are connected via bluetooth to your computer.
Turn on pda net on your DI and enable bluetooth dun.
Now go to your bluetooth settings on your computer and double click on your device, a new service should pop up allowing you to enable dun/modem and select that.
right click on your di bluetooth connection on your computer and create a dial up modem.
select the generic bluetooth modem, not the pdanet modem.
Type 123 in the phone number and leave the username and password blank and click connect.
Now you can right click on your DI bluetooth icon on your computer and select connect to the modem connection you just created.
After using my DI as a modem over bluetooth there are a few things to consider.
1. yeah it works great.
2. Its a battery **** fest.
Constant 3g with constant bluetooth = constant battery draw.
I would still recommend using your pdanet via the usb cable, seeing as this will keep the battery level charged, as well as same speed!
Aug 29, 2011 | Motorola Mobility Droid X
Hi i ve got a nokia 5800 and it keeps saying not able to swith bluetooth on ,, it has worked before i dont knoww what i have done
have you tried to restart your phone? if not, kindly try it and if your phone is still the same way you can try restoring it to its factory setting by clicking the menu-->settings-->phone-->phone management-->factory settings and select yes or try to master reset your mobile by just dial *#7370# and accept but before that i suggest that you should back up your file first.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Dec 12, 2010 | Nokia 5800 XpressMusic Smartphone
Bluetooth is not working in Lenovo 3000 y500 notebook
Uninstall the WLAN Bluetooth driver from the system properly and restart the system and after restarting the system then reinstall the driver properly and restart the system again and after starting the system then check
Jun 06, 2009 | Lenovo 3000 Y410 Notebook
Bluetooth can't detect new devices!
You might want to try to Reset Settings and see if that works first
1. Go to Menu
2. Select the Settings tab
3. Select Phone Settings icon
4.Select Reset Settings.
Once you do this, turn your phone off and back on, and try this next if u have Bluetoot of turn it back on.
1. Go to the Bluetooth icon
2. And select Settings
3. Select My Address
Make sure your My Bluetooth shows an address like
00:1k:54:nj:54:m5 (not a real address but should be same form)
If your bluetooth addres has been removed or corrupted contact me back.
Dec 07, 2008 | LG KU990 Viewty
BLuetooth Failure
I'm having the same problem as you.  I just tried turning off the phone and head set, restarting them, and then following these instructions exactly:   http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/cci/bluetooth_pairing_instrctns.php?p_headset=4224&p_handset=4662&p_cat=744
Seemed to work.  For now...
Aug 12, 2008 | Sony Ericsson Z525a Cellular Phone
Krzr k1m won't connect to bluetooth device
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
Nov 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 6280 bluetooth
sir,u try by going to menu>>settings>.connectivity>bluetooth>bluetooth settings>>bt visibility>>shown to all then restart ur phone after restoring handset then try to turn it on..else there is a fault in handset regarding bluetooth function.
Oct 14, 2007 | Nokia 6280 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
