Question about Sony STR-D565 Receiver
My right side speaker is on but very weak. I've troubleshooted and it isn't the speaker or speaker wire. What is wrong with my amplifier?
  • 3,083 Answers
Most likely there is a problem in the amplifier or filter stages, and this will take some troubleshooting to find and fix. You might take it into a repair facility and see what they would charge to fix it. The minimum of tools needed to troubleshoot the unit is an oscilloscope, signal generator, and schematic. Usually the problem ends up being power transistors, but it can be many other things.
Wish I had better news. Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 04, 2010
Where can i find a radio diagram for a 24 pin 05 cobalt with pioneer speaker system
Car Radio Battery Constant 12v+ Wire: Red/White .
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
Nov 03, 2016 | Pioneer Car Audio & Video
Lexus nakamichi 12 cd player repair
follow this steps and fix it. God bless you
blem: I get noise on my car audio system that disappears when I turn the car off.
Possible Cause
Suggested Solution
Alternator or ignition noise is being picked up through the power connection. Install a 12-volt noise filter between the power tap and the power input on your car audio. Back to the Troubleshooting Index Problem: The sound distorts at high volume when I play the radio in my car audio system.
Possible Cause
Suggested Solution
The radio wattage is too low to drive the speakers. Use a car amplifier to increase the radio's power. Replace the speakers with ones which match the radio's output. Back to the Troubleshooting Index Problem: My car radio only get one station.
Possible Cause
Suggested Solution
There is a problem with the wiring. Check the antenna circuit and rewire if necessary. There is a problem with the antenna. Check the antenna and replace if necessary. There is a problem with the radio. If you received more than one station with your previous system and you have already checked the wiring and the antenna, either replace the radio or send it to a service center. Back to the Troubleshooting Index Problem: My car radio keep running hot and blowing fuses.
Possible Cause
Suggested Solution
The wires to different speakers have been combined rather than run separately. Make sure that each of the speakers has 2 wires run to it. Combining speaker wires will cause this problem. Back to the Troubleshooting Index Problem: I lose my station memories in my car radio when I turn off the vehicle.
Possible Cause
Suggested Solution
The tuner memory wire may not be connected properly. Connect the yellow wire to your vehicle battery's positive (+) terminal or to a fuse that provides a continuous source of 12 volts. This connection provides continuous power for the clock and tuner memory when the ignition is turned off. Back to the Troubleshooting Index Problem: The amplifier stays on for a few minutes, then shuts off, then comes back on, then shuts off again.
Possible Cause
Suggested Solution
It is overheating due to power issues. Check your power ratings to be sure they match the amplifier's specifications. There is a problem with the amplifier. If the power ratings are correct, the amplifier needs to be sent to a service center. Back to the Troubleshooting Index Problem: When using two amplifiers, I lose the right channel on one amp.
Possible Cause
Suggested Solution
There is a problem in the sound system or wiring. Try swapping amplifiers or bypassing that amp. If the problem persists on the right channel on both amps, check the wiring and sound system. There is a problem with the amplifier. Replace the amplifier that displays the problem or send it to a service center .
Nov 04, 2013 | Car Audio & Video
Wiring a subwoofer in a 2012 civic coupe
Run the 12v power wire (usually the longest wire in the kit, mostly red, typically ranges from 8 gauge to 0 gauge) from the battery through the firewall and then to the amp. You can find a hole somewhere in the bottom right of the firewall. Don't connect the power wire to the battery or the amp just yet. Find a solid metal ground somewhere near the amplifier. You'll need to stay within 2-3 feet of the amplifier to maintain the best ground connection. A way you can do this is pull up the carpet and scrape the metal until it is bare metal with no paint left on it. If the amplifier is to be mounted in the trunk, many times bolts from the suspension can be found directly above one of the rear wheels. These suspension components usually bolt directly to the frame, making them an ideal grounding point.
Pull the aftermarket CD player out of the dash. There is a blue wire with a white stripe hanging out of the back of the deck known as the remote wire. The remote wire is a simple 12v signal that the cd player outputs to tell the amplifier to turn on. Take your remote wire that came in your amp kit and splice/solder it onto that blue-whitestriped wire and run it through the dash and then along the door jam. While you have the CD player removed, plug the RCA white and red plugs into the back of the deck where it says "Subwoofer Output." If your cd player does not have a "Subwoofer Output", or if you are using a stock cd player, you will need a device called an inline converter. It's a small box that has 4 input wires and the 2 necessary RCA output that will run to the amplifier. It takes the high level speaker voltage and drops it to a low level signal the amplifier can process. The 4 input wires can be connected to the rear speakers (+ and - for left and right)
Run all the wires straight back to the amplifier.you should run the power and remote control down the right as factory speaker wires run down the left due to fire risks if the power cable shorts out and you have your speaker cables down the same side it will blow your headdeck (cd player). RCA cables should be run down the center of the car as RCA cables can pick up sounds from wire looms and also air con vents power wires. se Speaker Wire to connect subwoofers to amplifier. Gauge isn't extremly important here, as long as the wire is copper, the resistance-per-foot is in the milliohm range, meaning there will be miniscule, if any, voltage drop across the wire.
Put a fuse into 12v wire in the engine bay no more than 0.5m away from battery. If your amp kit came with an "inline fuse holder", you'll want to find a nice location to mount it in your engine bay. Once it's secure, cut a length of the power wire to reach the fuse, and connect it to one side of the fuse holder. The other side (the side you just cut) is stripped and connected to the other side of the fuse holder.
Connect the power wire to your battery. There's nice ring connectors and even new battery terminals you can buy (and sometimes come with the amp kit), that make the battery connection much more solid, and looks better too. Lastly, connect the battery cable to the amplifier. Then under the hood clamp the wire down to the battery. A word of warning, sometimes you'll see a nice big spark the first time you touch the power wire to the battery. Don't worry about it! This is the amplifier charging the huge capacitors contained inside.
Do not turn up the volume or gain too high or you may produce clipping in the subwoofers. This is where the output of the amplifier peaks and stays there for a split-second. This is bad for the subwoofer because it holds the cone (the big circle part!) in it's fully extended or fully compressed state for the duration of the clip. Not only are you not producing a single decibel of sound during this microsecond, but you're also working the voice coil very hard and damaging it. A good rule for beginners is to play a nice loud song of your genre at your cd players 3/4 volume setting. Now, with the gain at zero, turn it up until it's obvious that it isn't getting any louder. The gain knob isn't a "volume" knob by any means. A gain knob should usually never be at it's full position.
Jun 01, 2012 | Car Audio & Video
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifier´s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Sony DB930 - Rear right speaker (terminal connector?) not working
You can open the reciever and see if there is anything visual. If there are any parts failures these would not be visable. You can check to see if there are any blown fuses.
You may have to give the reciever out to an experienced service tech to troubleshoot it to find out where the failure has occured. These recievers can be complex to service.
Jerry G.
Jan 08, 2009 | Sony STR-DB930 Receiver
Troubleshooting amp setup
You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
Jan 05, 2009 | Car Audio & Video
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Sep 01, 2008 | 1986 Toyota Pickup 4WD
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
263 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
