Question about Envision 19" Widescreen Flat Panel LCD Monitor
Sound has stopped from speakers?? everything is set to loud, mute is offjust relocated comp in room and have checked all the connections
  • mduncan349 Sep 04, 2010
    i dont see a spot for earphone on monitor, did find tag though, its a en7100s, can u tell me where earphone connection would be? thanks
  • mduncan349 Sep 07, 2010
    i believe speakers are in the monitor, never had special jacks hooked up for speakers before, been to microsoft website and went through their trouble shooting page with no fix! I dont know, this might be a 17" screen, info from back of it is EN 7100s
    I'll take any other suggestions you have, downloaded new drivers also.
    Thanks
  • 4,924 Answers
Check to see if you plugged it in the right plug in the back of the computer on the sound card ..it has to be plugged into the green out ..or if it is a sound card with more than 3 outlets ..than look for the SPK out ..(usually green) ..
there can be nothing unless you plugged it wrong ..or an sound card error occurred on the move ..
so ..
check the plug to be in the right one ...and best way to do this.. and see if ti is or not a computer issue ..is to start a song n a player ..raze teh volumes..(check the master volume ..and also the mute case on the master volume into the task bar ...the speaker icon )..and to be sure ..try to plug it first into the headset out in the front if it has one ...if it works it means that you just missed the right plug in the back ..so ..take them one by one .case it may be wrong wired and the plugs not in the right place ..
Let me know what you have done ..
and if you are sure its all ok ..but still not working ..we will troubleshoot it further ..
I mean checking the sound card to be plugged well..and reinstalling the driver just in case..But I thing that this will be not necessary if it worked well before replacing it ..
Just check the plug like I said ..and the mute from the computer 's master volume ..
Posted on Sep 05, 2010
    Genius:
  • 1,035 Answers
Hi. It must be your speakers that is having a problem. Try to plugged in an earphone and see if you will be hearing a sound. if nothing happens then this could be a sound card problem. Try re-installing the driver of the sound card and still same thing happened then this could be a sound card problem.
Posted on Sep 04, 2010
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Why did my speakers in my 2004 honda civic stop working
hi,its possible the internal stereo amp has packed up or someones blown the speakers by playing it too loud,or as above ,check the mute button first.
if its not the mute button,get an old speaker off a house stereo and connect the wires to where the car speaker is connect and see if get any sound,this way you will know wether the stereos working or not,if you get sound,then its a speaker problem,thanks for using fix ya
Mar 15, 2012 | Car Audio & Video
Headphone jack in tv has stopped working when putting speakers or headphones in is making a loud clicking sound. Is there anyway to connect speakers or headphones to the tv without using this jack? Have...
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Nov 14, 2017 | Electronics - Others
My Boston Digital BA735 speakers are not working. power is on. cords are correctly placed, volume on comp is not muted
Try to isolate the problem. Connect the speakers to another computer or mp3 player or stereo. Test the speakers for sound making sure all volume switches are on. If they work look to sound settings on your computer.
Oct 04, 2010 | Boston Acoustics BA735 Computer Speakers
When i watch dvds,the background noise is loud
Go to your set up menu, navigate to speaker set up and check your sound levels to front, center, and rear channels. Adjust as needed to fit the room. My Sony has a test tone option which sends a signal (at levels selected) to each speaker to check sound level and if speaker is connected and in right place.
Dec 28, 2009 | Sony DAV-FX900W System
No sound..relocated computer, thought everything is hooked up.
Make sure the speaker wire to the computer is to the lime green plug on the computer and power to speakers and make sure volume control on the computer is not muted
Aug 07, 2009 | HP Compaq WF1907 Monitor
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Akia PDP5016h no sound
replace the speakers my friend. you had probably turned on the speakers so loudly that the lead inside the speaker got loose thats why its faulty now.
Apr 15, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
No sound
check ur audio driver setting
Jan 21, 2008 | HP Pavilion a1000n (PS567AA) PC Desktop
Envision 19" Widescreen Flat Panel LCD Monitor Logo
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
