Question about Whirlpool Dryers
Duet gas dryer not drying - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Why doesn't my dryer dry clothes?
You can find the Installation Instructions and your owner's manual here: http://www.kmart.com/whirlpool-duet-174-7.4-cu-ft-he-gas-dryer/p-02692332000P The links are about halfway down the page and are in red. There are instructions for cleaning the lint screen, which if clogged, will effect the drying time. Hope this helps.
Jun 25, 2014 | Whirlpool Duet WGD96HEAW 7.4 cu. ft. Front...
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Duet gas dryer only drys on timed
One thing you can do is clean the sensor strips located inside the dryer. Get some windex and clean the coating off them. Dryer sheets rub against the strips and form a barrier. The machine THINKS the clothes must be dry because it ain't SENSING dampness from wet cloths rubbing against them sensors.
Oct 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Why is my whirlpool duet gas dryer is take too long to dry? even the bed sheets.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 14, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
DUET DRYER WON'T DRY CLOTHES ALL THE WAY THRU -
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
I ahve a duet gas dryer and it will not get hot
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
Mar 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
